Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
@agentgates:
Are you still working on those videos? I know things are a bit hectic now but it sure would be nice to see it in action.
agentgates
Quote from: Mannix on January 07, 2010, 07:10:55 AM
just a quick one,
Steven said that ss units must be located  in the middle of the coil.. worth a quick try tony
Thank you, I'll certainly try this, however I don't know the reason. :)
UPDATE
Ok, I've got it now. :)
I think he experienced some electrostatic discharges around the torroids so he put them in the middle to protect the ICs.
ramset
Otto
I 'Know' Tony said no specific frequency
Works all over ,but reccomended between 8-100hz so as not to broadcast
Its in first few posts by Tony
Chet
Thanks Grandma
Bruce_TPU
Hi Tony,
Thank you for answering everyones questions.  But, I am not clear on mine.  You gave the output voltage, but not the output amps when answering my question.  If you could clarify what the output amps were, that would be great.  There are concerns that this may simply transforming the power into high voltage, that is why amp readings are needed.
A circuit, even roughly drawn would also be great, posted.  This is day 2 and still no circuit.  Even if it is the one you started with.  We know you are working hard on simplifying the electronics, which we are grateful for, but we would like to peek at the other circuits you have used to make it work.  Just draw it and take a picture if you need to save time.
Lastly, a video, showing power in, volts and amps and power out, showing volts and amps would also be wonderful.  Do this, and the replications will be flying.  Thank you!!
Cheers,
Bruce
agentgates
Quote from: ramset on January 07, 2010, 07:47:07 AM
Otto
Chet
I think I said 100Hz as lowest, but anyway, should work with 8Hz but will cook a bit on the coil if you go for it with high current.
