Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
onthecuttingedge2005
How do you get a lazy conservative slave(Electron) to do work? you crack the whip on it(Wavelength), to make it work more efficient you must speak the same language(Frequency), the amplitude of your voice makes it more demanding.
I hope this analogy is helpful.
Jerry ;)
agentgates
Quote from: onthecuttingedge2005 on January 13, 2010, 12:04:04 PM
Jerry ;)
That is nice. :) What exactly happening in subatomic level is not 100% clear. I have a theory that I will try to make solid in the nex couple of days, until then I wouldn't push it hard to get people confused if that wouldn't fit. But what is already sure is that we spin them up to a very high speed at the intersecting points outside and they just start flowing spontanously. (The deeper understanding in this process is what I am expecting in the next couple of days)
Magluvin
But will we see it before you complete the theory?  =]
Magluvin 0 7
SPP-48
Quote from: agentgates on January 13, 2010, 11:47:06 AM
I think many people got confused here with their coils. For those who have problems with results, here is the formula again how to calculate the length of the tube to get the 45 degrees:
l = (d x PI) / 6
"l" gives the length of tube to cut
Hi Tony
Using the formula gives me a height of 41.89mm for an 80mm diameter tube. Is this correct. I recall you were using a 70mm high coil originally.
l = (80 x 3.142)/6 = 41.89mm
Cheers
Sam
ramset
007
Patience Grasshopper ;D
This will do what it does!! :o :o :o
[Don't ask me what "that" is]
Chet
Thanks Grandma
