Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
mrd10
explanation on some of the photos:-
-the coating on nylon rings was a mix of epoxy and ferrite powder
-nylon rings made from cutting board material, I made several in one go..
-built couple of oscillators, one is 555timer and the other small_td1.jpg, looking at building an astable cct as well using two fets...
mrd10
Hi fellow experminters, I recall and can pretty much reproduce this effect, refer to the small_td1.jpg oscillator drawing and associated unit P1011001.JPG oscillator, using 9volt battery, and on the secondary I have a 12 miniature light bulb, the light bulbs intensity is very bright,
now without using the oscillator, and i connect the battery directly to the light bulb, it is only about half as bright.
I worked out with the scope that this oscillator was about 3khz, and you can here a slight hum.
it is very easy to build, take you prob about an hour to do, so what i would like someone to do, is say hey this is interesting, or it is quite normal....
Interestingly enough though the bulb was much brighter, I came across the cct by accident, when i was investigating tesla coils.
e2matrix
Nice work mrd10.  It seems this thread has been ignored for quite a while since other newer threads have started on the TPU.  I'm very interested in the situation where you describe in the text in that last picture how the circuit destroyed itself.  What input power were you using?  Do you think this was a sign you have hit on the right combination of frequencies where a power surge may be seen?  Any other info related to that event?
mrd10
@e2matrix
no no I got that from this webpage while investigating tesla coils:-
http://tacashi.tripod.com/elctrncs/ssstc/ssstc.htm
same site but using 555timer instead:-
http://tacashi.tripod.com/elctrncs/555sstc/555sstc.htm, that's where i made the 555timer cct from
still further testing required once ive wound few more coils.
I used the 1 transistor cct, but on small toroid with interesting results, never got to point of being destroyed, maybe cause i was using 9volt battery rated at 200ma, thats why I wanted someone here to simply build it and tel me, yeh thats interesting or neigh, thats normal, I used miniature 12volt filament lamp as load...
giantkiller
