Solid State Orbo System
0 Members and 23 Guests are viewing this topic.
Bruce_TPU
Quote from: JamesBe1 on February 16, 2010, 05:08:14 PM
Thanx Groundloop.  This thread has inspired me to get off of my backside and start winding.  I have a great deal of experience with test equipment.  As soon as I fix my pulse generator I'll be able to start testing and sharing my results.
Hi James,
Welcome indeed!  We always need more builders and less talking heads on this forum... LOL
@ ALL
I have mixed my first batch of mad scientist ingredients for my nanoparticle flux bars (and I did wear a mask and gloves, cause that fiberglass stinks!)
But, I kinda messed up the first forms.  I did not fill all of them, but the ones I did fill, I forgot... the VASELINE.  You see, that is suppose to go into the forms (rubbed) first and then the mixture poured.  It will be dry in less than two hours and I will know for sure.  Also the mixture was a little thin I think.  I weighed the iron oxide and other ingrdients, so redoing should be easy.  I just need 6 or 7 tbs of fiberglass instead of the 8.  Maybe.  But the good news is that I have enough "stuff" to do this about 40 more times...LOL  So in two hours I will know.    ::) ;D
Bruce_TPU
Hello ALL,
Well it is more than two hours and bars are not dry.  I think that if it is not dry by the morning, I will need to change the order in which I mix the ingredients.
Tonight, I mixed first the iron oxide, and then my nanoparticles, and then my fiberglass epoxy, and last my hardener.
If they do not dry by morning, I will wash the forms off and mix again tomorrow in the following order:  (and remembering to use vaseline on the forms for when they do dry...LOL)
Cup 1:  I will mix iron oxide and nanoparticles
Cup 2:  I will mix epoxy and hardener
I will then add cup 1 to cup 2 and mix.  This will work!
Cheers,
Bruce
http://www.energyfreedomreport.com
synchro1
I believe JLN could improve his SSorbo output by replacing the copper wire wound output coil with a cluster of crystal alternator diodes. The alternator generates current from the stretching and collapse of the intersecting rotation of the magnetic fields, and the crystal diode attracts and collects the power from this type of torsion better then anything. A ring of crystal diodes should attract and rectify power from a wider portion of the scalar wave. Another thing, I wonder if JLN could light more LED´S as we've seen demonstrated by our Joule thief experimenters, where hundreds of LED´S are connected and illuminated in series with no apparent rise in input power. I wonder also if his input would double if he doubled the wraps on his output coil, without increasing input. Broad spectrum power receiving antennas are currently under development by cell phone manufacturers. This kind of output receiver coupled with resonating toroids would yield a an infinity OU generator. The magnet appears to be an inexhaustible source of electric power, that's transformed into electricity, defying both the Lenz law and the second law of thermodynamics.
Staffman
@ All,
I did a quick replication of JLN's 2SGen. It's cool. Here's my setup. I used the Ainsley circuit for the pulsing circuit. My Toroid is 28.3 mH on a Magnetics Core ZP-42507-TC wound with 22 AWG (uh-oh! didn't count wraps). My pick-up coil is 30 AWG, at 14.7 mH using two spools of Radio Shack magnet wire on a single spool bifilar style. The output circuit is basically the same as JLN's but I used a 1uF cap instead of 22uF (I haven't tried other values yet).
I've haven't gotten round to soldering the Ainsley circuit on GL's board yet, so I'm using an IRF630 for the Fet on a breadboard (ala Forest Mims III electronics board). I'm reading the Fet at 4.45 V before I hook up the toroid. At the output on the pickup coil, when it is unloaded I'm seeing 10.3 to 11.2 volts (tricky connection for 30 gauge wire). When the circuit is loaded with simple red LED's, the voltage levels off at 3.4 volts. I've hooked up as many as 3 LED's and the voltage seems steady at 3.4 volts. I would hook up more, but I just noticed the Fet is giving of that characteristic smell like it's going out. Needless to say, but it needs a heat sink.
The magnet I'm using is a 1/4 inch by 3 inch cylinder Neo. On my setup, I'm touching the magnet at the top of the toroid instead of at the bottom. When the magnet is touching the toroid, the LED's light up. When the magnet is not touching, the LED's turn off. Cool!!!
Edit: Put on a heat sink. Hooked up 10 LED's. They all lit up, but a little dim. When I adjusted the frequency to 20.95 kHz, the LED's got noticeably brighter. Something a little strange however... The Duty cycle is at 29.6%. When I try to adjust it higher, the LED's go out. Tested the output voltage, showing 4.36V on the scope.
Bruce_TPU
Hello ALL,
Steven Mark once said that "there are some interesting characteristics of toroids, learn them. "  Boy he sure wasn't kidding...
Please check out the latest from JLN Labs:
http://jnaudin.free.fr/2SGen/indexen.htm#moving
I am curious about this one, indeed...  :o
Cheers,
Bruce
http://energryfreedomreport.com
