Solid State Orbo System
WilbyInebriated
Quote from: FatChance!!! on March 19, 2010, 04:13:33 AM
If you had a real working OU device without any doubt, all you'd have to do is to let it be independently verified by a serious
organization, like a university or similar, and by their help and support you could either sell rights or start producing the device.
Meanwhile you would become famous due to all the publicized articles in acknowledged scientific magazines.
how faux-naïf... ::) in reality, you would be ostracized just like pons and fleischmann, and just like pons and fleischmann, your work would quickly gain a reputation as pathological science.
FatChance!!!
Quote from: WilbyInebriated link=topic=8597.msg233301#msg233301 A=1268986726
No, this would not be the case if it was really working beyond all doubt.
And I'm not talking about some small and strange anomalies here.
I mean a strong and useful output of several kilowatts which can't be mistaken for measurement errors.
wings
Quote from: gravityblock on March 18, 2010, 12:39:35 AM
Here's a patent with images to the "figure-8 configuration" I previously posted, http://www.overunity.com/index.php?action=downloads;sa=downfile&id=378
It appears both patents are using the same concept with slight modifications.  I think the same individuals have a few more similar patents along the same line.
GB
@ GB
VIRTUAL AIR GAP
nice reading  ;)
http://www.ele.utoronto.ca/~lehn/conference_papers/CP16.pdf
Bruce_TPU
Good afternoon Everyone,
I am feeling chipper this morning!  LOL
The information to purchase Brooks Coils Identical to mine:
http://www.coilwinding.us/    Is their Website
Polytech Coil Winding is their name.
Tell them you want to order, "Bruce's Brooks Coils" when you call.
They will only accept Paypal, I believe, for payment.  These coils are good for many experiments.
Experimental Note:
I forgot to mention last night, that when the Aluminum was added, there is tremendous vibration now of the SSG3, when running on 12v.
I always believed that SM wrapped the collectors in Aluminum wires as the control wires on the TPU, for many reasons, including the fact that when asked if the control wires were copper, he replied, OTHER.  I know they are not steel, and when I wrapped an exact replica of the 6" TPU, according to the given winding instructions, I used steel wire for the controls and weighed it.  Determined the weight if I had used aluminum wire and found it would have matched exactly to the engineers reports stated weight, less an ounce or two for electronics and battery.
Now, I am solidly convinced.  magnet, alum control wires, copper stranded collector, three freq's to intermodulate.  30.075 KHz 222 KHz and 115 KHz for a 15" TPU.  Sorry for getting off track here, I just thought I would mention this...
Cheers,
Bruce
freeorbo
Any version of the 2sGen is "over unity," because all of the energy going through the toroid can be accounted for, but none of the energy coming out of the pickup coil can be.
Your output isn't larger than your input, sure, but your total energy present in the system (toroid coil and pickup coil) when it's running is greater than the energy in the system when it's off.
You can't show any energy being removed from the toroid circuit that is appearing in the pickup coil. The energy in the pickup coil isn't being converted from anything in the circuit.
It's OU, it's just not usable for anything.
