Solid State Orbo System
gravityblock
Quote from: wings on March 17, 2010, 07:49:31 AM
http://www.google.com/patents?id=FS6gAAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q=&f=false
Here's a patent with images to the "figure-8 configuration" I previously posted, http://www.overunity.com/index.php?action=downloads;sa=downfile&id=378
It appears both patents are using the same concept with slight modifications.  I think the same individuals have a few more similar patents along the same line.
GB
exnihiloest
Quote from: FatChance!!! on March 17, 2010, 02:10:23 PM
Yes, learning is good but not from JLN or Bearden. They are not serious at all.
Bearden's blah never gave tangible products. He is a FE guru.
JLN is very different. The problem with JLN is the interpretation of what he observes: his explanations are biased. Nevertheless his experiments are rather well performed (except some measurements) and documented. They are reproducible and instructive. So imho we should reject many of his explanations and his conclusions about OU but not the remaining experimental matter.
I've been around to long to accept crackpots or ignorant perception.
I'm so tired on all bad testing or hidden test procedures. Avoid ignorance at all cost.
I agree with you.
void109
Quote from: FatChance!!! on March 17, 2010, 02:12:35 PM
If anything you replicated was overunity you would be famous and rich by now.
Well...are you?
I dont think either I nor him (I may be wrong) have claimed OU.  As far as I can tell, he's just running interesting experiments with interesting results.  And even if I did have an OU device, which I dont, how does that translate to instant wealth.  You are just being beligerant.
Bruce_TPU
A Pleasant Evening to ALL,
I am back from my travels, where I also had the opportunity to think through several ideas....
One of them did not work, but the other...WOW!!  Doubled my Amperage and it continues to rise, but the rotor comes to a stop.  And I think I can get it to increase some more...  :o  INPUT power is down...  :D
First, the latest Power data and then an explanation of what I did and why:
INPUT into the SSG3:
3.2 Volts
5 milliamps
0.016  Power
OUTPUT from the SSG3:
0.8 Volts
2.5 milliamps
0.002  Power
SSG3 still being switched at between 50 and 70 Hz by rotor and reed switch... ;)    Wow, wait till I give it some speed!!
Tonights super successful experiment that worked:
I have been still thinking on ways of manipulating magnetic flux in a physical manner, and have been playing with magnets and aluminum this evening.  Suddenly it occurred to me, that a small portion of the magnetic flux might be either diverted, or delayed to increase power production...
So.o.o, I added one large piece of very thin aluminum sheeting between the two popsicle sticks being used for my air gap between the large magnet and bottom coil.  (bottom coil also has a toroid and magnets UNDER said toroid in attraction to Large said magnet)
It worked, WOW, and doubled my amperage out!  Why exactly?  I can only speculate in my minds visualization of the fields.  But now I must optimize that piece, length, height, etc., and then try some more aluminum sheeting in other "strategic" places, being sure to not let the aluminum touch either the magnet or coil.
Very encouraged,
Bruce
FatChance!!!
Quote from: void109 on March 18, 2010, 11:10:45 PM
JLN has claimed OU results in several replications. First one I recall is the MEG.
If you had a real working OU device without any doubt, all you'd have to do is to let it be independently verified by a serious
organization, like a university or similar, and by their help and support you could either sell rights or start producing the device.
Meanwhile you would become famous due to all the publicized articles in acknowledged scientific magazines.
