Solid State Orbo System
Groundloop
Bruce,
Yes, the circuit is difficult to tune and the output is like radio frequency.
I move a wire and everything changes. Sometimes I can measure voltage
on the DVM with one wire only.
I have made a diode bridge and used a 2,2uF 630 volt capacitor. The high
volt is for safety when I forget to clip on a load. So I already have that.
I have tried charging another battery and that works OK.
I think that I have brought this setup as far as I can go. So next I will
start making the setup with a center toroid and several output coils.
I think that is the way to go.
My hope is also that other will start to replicate this. Soon 22000 members
on this forum. How many is doing research?
Alex.
Groundloop
Oc,
Thanks for the link. I will check it out.
I also found a magnet man in Germany.
Alex.
Bruce_TPU
Quote from: Groundloop on January 08, 2010, 04:26:24 PM
Bruce,
Alex.
I agree, I too believe that more output coils is the way to go.  Also, it will allow you to wire the outputs in parallel and increase the amperage.
There will be plenty of replicators once we show some real power on the output vs input.  Not many have your electronic skills.  So, hang in there and keep going!   ;)
I am still awaiting my toroids and magnet wire that I have ordered.  I will be building as well.  I have a brooks coil I want to test as a Generator coil.  I also have my mechanical version build, awaiting a toroid.
P.S.  How many Ohms is one of your toroids?  I looked back at page 1 and didn't see that info.  Thanks!
Cheers,
Bruce
Staffman
I am also awaiting parts. Should be in sometime Monday. I've also ordered some nylon coated steel wire to test an idea someone made on the mechanical thread. The suspense is getting unbearable...
