Solid State Orbo System
Started by Groundloop, January 06, 2010, 12:21:24 PM
Staffman
Groundloop thanks for the help. Much appreciated!!! Ordering the N-Type you mentioned and will also order P-Type for below....
Is there a way you could test to see what the back spike voltage is? We may be able to capture that back spike into a cap bank for added efficiency. Just a forward looking thought.
Groundloop
Tadej,
Welcome to this forum. It is always nice to get more people interested in free energy research.
I will try to answer your question. First, why use magnetic shielding instead of ordinary coils.
The short answer would be, I have already built the Tom Barden MEG and it did not work for me.
So I want to try something new instead. When we use magnetic shielding then all the power we
get in the generator coil is for free, according to the theories from Steorn. So if we can use LESS
power in the toroids to shield the magnetic field than the power we get out of the generator coil,
then we will have free energy. Probably not an easy task to do but worth trying.
Your English is not a problem, I can understand you quite fine.
Again, welcome, and good luck with your build.
Alex.
Groundloop
@Staffman,
I can measure the voltage tomorrow afternoon. It is past midnight here and bedtime.
We can NOT capture that high voltage. I have (accidental) tried that and the output in
the generator coil drops to almost nothing. We must allow the positive voltage spike to
be big. The negative voltage spike will be channeled to ground via the BY255 diode or
if a mosfet is used, through the internal diode.
Alex.
Staffman
@ all
Just built the Anslie circuit, all except the Transistor (just ordered IRFPF50 from Mouser). Circuit works great so far at 9V DC (instead of 12V). Scope shows a nice square wave at 10.22K Hz, 14.8% duty cycle. I can't wait till I have this finished. I have some RF suppressor toroids comming as well. I ordered the Fair-Rate suppressor toroids (PN 2661102002) I'll let you guys now if they work out.
gotoluc
Great find and topic Alex ;)
This is exactly the kind of thing I was starting to experiment with. It was clear to me that an over unity device would use permanent magnet flux to output extra energy. Richard Willis Magnacoasters device works on this principal.
I have 2 identical large toroid transformers of 300va each. Primary is for 120vac @ 100mH and 1 Ohm with double secondaries of 40vac each @ 14mH and 0.2 Ohm each.
Do you think these would work to test your device?
ADDED: Alex, I tested these toroids with my inductance meter and when I approach even a large 2" magnet the Inductance does not drop since the cores are steel. If your effect is based on the inductance drop that a magnet does on a ferrite core coil then these toroids won't work.
I do have 4 of the identical ferrites (attached below) you have. Been collecting them from old CRT monitors I strip for parts;D... looks like a popular size.
FYI: I posted this in the other topic:
Hi everyone,
just to let you know that I donated out the last 3 RA circuit boards Groundloop had professionally made and donated to me for free distribution and mailing to help anyone interested in testing the RA circuit.
Thank you once again Groundloop for your kind generosity.
Luc
