Solid State Orbo System
Started by Groundloop, January 06, 2010, 12:21:24 PM
Magluvin
thats the biggest joule thief i have ever seen!  Just playin.  =]
but the stacking of the coils being never ending is interesting. Like the coils become 1 and the field is treated like 1 big pickup coil and the fields have to travel the full path to complete the field as one big singularity.
What are the ohms of these coils? have you tried paralleling them?
Mags
Bruce_TPU
They are 253 ohms each. Brooks coils have some very special qualities not found in other coil types.   ;)   Joule thief today, SSG3 tomorrow...
Tomorrow I think I will wire all of them together in series, the outputs, remove the LED's and replace them all with one 12volt DC bulb, or two.
Then I want to work on the tuned resonant LC tank... and capturing that bemf.
I am really curious what a real electronic circuit will produce.  Once that is in place, the last thing to play with will be the power going through the bias.  But that will be the last thing.
Of course, I do have a hankering for trying some standing waves inside one of these coils, just for kicks...lol no pun intended.
Any other ideas are always appreciated.
Cheers,
Bruce
Magluvin
Try this if you will. Its easy and conclusive to my thoughts on those coils from what you just wrote.
make yourself a coil of 18 to 20ga of like 50 turns, and 2 in. in dia. Then try what you are doing with that. Treat it like an S2gen just for kicks.  Your current will increase by an order of magnitude.  The coils you have are too high in ohms for current. you can put 25v across one of those coils and the current measured there is about the best you will ever get out around that voltage. very nice coils, but better to have low ohms on a gen coil to drive things. If your input is 5v, you should get around 40 to 50v no load. If your coils were putting out 250v, then as you load it down, the current would be increased. and as it goes below 25v due to load change, the current would be more as the load decreases in ohms.
try it and you will be close to powering bulbs with just gen power without bemf added.
My goal is to get my output to around 18v with the little interior bulb and i will be at or near unity.  Im at 14.7v at about 250ma at this time. i get about a 1/2 volt increase with playing  just about every couple days, when i do work on it.
you will be happy you tried it. =]
mags
lumen
Reading these posts, I wonder why no one has this thing working OU yet.
If the toroidal coil is actually unaffected by the secondary load (output coil) then this should be easy.
Simply wind the toroid and place the magnet in the center and connect it to the meter to get the inductance. Then using the inductance, select a good capacitor value to get a resonate frequency in a reasonable range, and connect the capacitor either serial or parallel to the winding.
Apply a frequency generator and scope and tune for optimal resonance.
Place the resonating toroidal coil into the secondary and measure the inductance of the secondary coil and set it up to resonate at twice the toroidal frequency using the same method as the toroidal setup.
The entire unit is now tuned to the best possible output and if not OU then this setup probably cannot work as an OU device.
synchro1
@Bruce,
          The domain flip must trigger a scalar wave that is like a Tsunami in the Magnetic background tissue that the world around us is immersed in, output coils could theoretically be stacked to infinity!
