Solid State Orbo System
Started by Groundloop, January 06, 2010, 12:21:24 PM
magneto_DC
Another way:
We WANT B-flux NOT leaving core!
Is Episode 8 (simmulation) right way?
Is Episode 9 right way?
Are both?
When yes,...
....Where is E ~dA/d.... (x,y,z,t) biggest? In what direction?
How to grip it? How to do winding?
I dont have an idea, how curl-free A looks like, and how E made from dA/d... looks like.
So, I WANT close-loop B, I WANT curl-free A, I DONT want bemf anymore.  ;)
magneto_DC
synchro1
Nicolay E. Zaev determined that ¨direct conversion of environmental heat to electric power is possible in the process of charge discharge¨. After the toroid cools from the demagnetization, it converts environmental heat to electricity. This is called Work, and is the opposite of entropy. The toroid converts heat from around itself to do the work of generating electricity. The amount of work is a function of the material alloy. Some alloys can do more work than others. Zaev has them classed according to their Lambda ratio, input to output. Nanoperm is at the top end of the scale. The toroids that are not cooling are not domain flipping and are not generating any power from conversion of room heat. Temperature loss is directly proportional to output!
Bruce_TPU
Hi Gyula,
Okay, battery is recharged, and found out that I had also blown all of my 4 large LED's.
Replaced them with a different LED.
Any who, with no load, I ran the following test:
SSG3 Ohms reading:
50.3 Ohms
No Load Voltage:
30.2 volts
50.4 resistor added in parallel
New ohms reading is 25.3 ohms for SSG3
No Load Voltage
1.8 volts
On a side note, I am lighting 4 led's in series, 25ma 3.6V (max) and also in series with them is one 28V 40ma bulb.  LED's fully lit, a glow on the bulb, and 15 volts on volt meter.
If you can recalculate for me, what size cap to add and I will get it ordered.  Thank you!
@ ALL
I did get a hold of the laser thermometer and it shows a definate drop in temperature... But only 3 degrees, when running.
I suspect (and cautioned) that the magnetic fields were effecting the electronic temp probe.
But, I still wonder...LOL
Any who, parts are in from digikey and it's time to play!
Cheers,
Bruce
http://www.energyfreedomreport.com
Bruce_TPU
Evening ALL,
I ran two very intersting experiments this evening, using the exact circuit as posted by JLN Labs.  Strange results, at least to me, but you can decide and comment.  Tomorrow I will replace resistors with lesser values, and with lights after wards.
Self explanatory below.  Pay special attention to resistor values and output.
Cheers,
Bruce
exnihiloest
Quote from: gravityblock on March 08, 2010, 05:26:48 AM
Why does this cooling effect bother you?
Your reply is the proof that you, not me, is bothered with cooling. You spoke the first, not me, about cooling in this thread.
For me there is no cooling so I'm not bothered!
If I detect one in the future, I will inform you.  ;)
