Eccentric Transformer theory
Started by armagdn03, January 07, 2010, 05:50:37 PM
armagdn03
Quote from: forest on January 15, 2010, 01:51:44 PM
Think about it once again somehow you may find that I have right.Lenz rule you described gives energy.True.
I agree. However this is because something is taking part of len'z rule response away from source and that is ambient background between primary and secondary.Finally you should see that you don't need lenz rule because all will be "eaten" actively disconnecting primary from secondary.That will allow amplification of power.
whip it!
http://www.youtube.com/watch?v=h1nsz3pK6i4&feature=related
There is space in between source and reciever, that is the point of all this. However what you are insinuating has no real basis behind it. I have given mechanisms, math behind it, and simple demonstrations showing it to be true. Saying that I am incorrect and that the space inbetween is the reason is a bit self defeating.
As to this statement
"Finally you should see that you don't need lenz rule because all will be "eaten" actively disconnecting primary from secondary."
Again someone has completely missed the boat, observed the effect, but does not see its mechanisms at work. You DO need Lenz law always. It is always present but decreases with the square of the distance. This is found in all sorts of examples. Try measuring Q on a resonant coil, then put your hand near it, there is space in between...but your hand acts as a load, (and changes capacitance) and when re-tuned to resonance, you will find a decrease in Q, meaning a lenz effect has taken place. It is misleading to say that it has been "eaten" it is still operating and the maths that I show predict this, and the experimentation backs this.
You cannot say that I am wrong and that really it is because of the space in between, and Lenz law is really eaten because of it....that is just repeating what I have shown but with no real thought behind it.
I wish I could turn my brain off sometimes, then I could get some sleep.
forest
you are wrong. I said not about empty space  ::) ambiend background is something else, it IS ACTIVE
forest
are you on south or north hemisphere ?
darkspeed
forest
