Our black pope and his jesuits, a look at mankind's enemy...
Started by Gauss, January 08, 2010, 02:59:52 AM
Gauss
Jikwan, you now realize how easy it is to defeat evil?  About stress for a job interview, don´t worry(WuWei), if you are meant to get that job it is yours.
About your water engine, why not combine your system with my(or rather my friend´s) system? Doble in the 20s needed 30 secs to start his steam engine, I guess that could be acceptable in most cases even today. BUT as you say technically complex and explosion risk if you mess up.
So start up with HHO and add steam after a few minutes from a separate steam boiler? No matter if you have temperature jsut run on HHO and whirled air, the air inlet whirling will have immediate effect since a right or left whirling of air will ionize it no matter temperature(higher temp is extra beneficial).
This idea is super simple. Get a steam boiler and get an HHO dry cell for high pressure. At start up no steam and HHO is expensive to produce, as soon as pressure mounts efficiency goes overunity. If your HHO system is superb why not use it, just build it for high pressure? We can accept a few minutes of running with bad efficiency, still a huge progress against tech of today.
I must add my current focus is not this system(too tiresome(expensive) and slow to build at this stage, maybe this summer I can finish it).
Look at this one: http://guns.connect.fi/innoplaza/energy/story/Kanarev/analysis/index.html
In my humble opinion, this is the easiest experiment for extreme OU you can do and a near future mass market app. Normal electrolysis with lye, 1% duty cycle, 135 Hz, 5V pulse. Water flow needed. Try 5 mm spacers and two circular plates with water inlet and water outlet. This experiment everyone should do... COP 42 is not bad... And then we still throw away the residual HHO, in fact we could use that too... ;)
Compare the normal electric AC heater mounted on a baby swinger with this system. The AC heater(100% duty cycle) runs with the baby swinger back and forth while this system just push for 0.5% of the time at both ends. The rest of the time, we let the water do the work.
Each pulse will turn the water molecule(dipole turning according to positive and negative plates) causing friction inside the water, then we wait until it is stirred up again from the whirling, then we put another pulse. So easy and still we have not seen it.
Why don´t we look at the easy progress? If a professor gives us a detailed system with COP 42, should we not do that first??! Instead of messing with complex systems that have led us astray for so long. Each time anyone gets something OU working we will have huge progress. Just work open source, my sincere advice.
angryScientist
Just woke up again. Mormons once again proved them self's to be evil as hell in the spiritual realm.
It seems like the worst lie one could tell is that they are good people deep down.
Avenueoflight
They like the JW leader saw an angel named Moroni ( I moron) and gave them both their visions during the same time????????? Same non biblical Katholic SUN System Of Lucifer worship that every MAN-MADE Religion upon this earth falls under. The Father nor His Son created religion, man did for power, oppression, money(carrot dangled before them) like the kingdoms offered to Jesus. Same Sun sacrifical blood death system since babylon. This is a planet of death which is a theatre unto the host that knew not what sin was; they as we are seeing what 6000 years under Lucifer//satan brings forth; thus, we shall NEVER want to sin ever again.  We must be heart sick for a place of righteousness where we will never be violated again.  No MAN is good. Stop by my site and do some real deep searching... lot there.                            Mike
Gauss
Avenue, I see you have done an admirable research about truth, that is good.
Now my advice is you move on to making a change starting by yourself. Trouble is, digging too deep into mud creates negative energy for yourself and zealotry leading nowhere(there is no chance fighting demons on their terms). Finding positive HF energy and positive personal power is the right way to go I believe. I spent alot of hours just like you have done finding out about all these things(ie Nostradamus created the Jesuits and he was a black magician and what he predicted is what the jesuits try to make true etc etc).
Nevermind about the jesuits, start purifying yourselves and get a white aura first(easy to say, VERY HARD AND PAINFUL TO DO IN CASE YOU FELL DOWN DEEP INTO RED OR EVEN BROWN). Then nothing can trouble you, no jesuits, nobody(as for negative, dark aura people accept them and feel sorry for their poor enlightenment, do not get aggressive by any means) and no worldly trouble.
My advice, perform your work well, keep "normal" in society, start practicing FG, send righteous thoughts bringing evil down by eliminating their bad thoughts, karma, bad notions and external interference, in fact you only disintegrate their evil energy. When you meet good people tell them about FG and they will start doing it, I promise.
The top human level is just incarnated demons today. Demons took over alot of people when they fled destruction a few years ago. Disintegrate them by sending righteous thoughts.
There is virtually nothing evil left in other dimensions today(maximum evil was in 2001 so they say), only this dimension is awaiting the thorough cleansing(just like bible says will happen). So time is pressing for everyone wishing to raise themselves.
I give you an example story from an open third eye about your president´s aura colour(it seems he is taken over by a demon just as described in Zhuan Falun):
As you know, I have the spiritual gift of seeing auras. When I look at people, my spiritual eyes see shades of gray, from white to black. Over the past two months, I have seen pictures of Barack Obama, from childhood to now, bleeped on various news channels. It has been interesting to watch his aura get darker and darker the older he got. I was definitely not prepared for what I saw during the last presidential debate. Senator Obama turned and looked directly at the camera while answering a question. I saw that his aura was black, not just the dark gray I have been seeing, but black. Superimposed on the black was a hideously evil face, like a gargoyle’s face, or the scariest evil monster you can imagine. Then the words “Pure Evil” came to my mind. This disturbed me so much that I began to cry. I didn’t cry out of fear of Obama, but out of concern for our country. Imagine having the devil himself run this great country. If Obama wins, Satan will be running the country.
