New Permanent MagnetMotor-concept!
Started by dietmarhohl, January 14, 2010, 03:57:58 PM
dietmarhohl
Hallo friends,
in the links for you a new OS concept for an PMM under;
German:
http://www.magnetmotor.at/wissen/PMagnetMotor_de.pdf
http://www.magnetmotor.at/wissen/PMM_EB_Dreieck_A_N40x.pdf
http://www.magnetmotor.at/wissen/PMM_EB_Dreieck_A_N40_chart.pdf
http://www.magnetmotor.at/wissen/Aufbau_Dreieck_A_N40.pdf
Englisch:
http://www.magnetmotor.at/wissen/PMagnetMotor_e.pdf
I need help for re-calculation in a full version of QuickField.
An calculated factor of 1:3 made in the FEEM-Simulator is
absolutly not normal.  Thanks!
All the best!
Dietmar Hohl ;-)  Linz/AUSTRIA
www.magnetmotor.at  /  d.hohl@magnetmotor.at
Blainiac
Wow!  That's an interesting idea.  Have you only done simulations?  Although I see exactly what you're doing, I would hope that 'small' repulsion wouldn't cause a problem.
I conform to non-conformism.
sheadijn
This is a very interesting concept. Where can you get triangle shaped magnets? I would be willing to build this. Also please clarify the positioning of the magnets in relation to each other. The diagrams show a rotor between to stators. I may have to create a picture to illustrate my question.
zogger
Quote from: sheadijn link=topic=8647.msg232107#msg232107 A=1268308962
http://www.kjmagnetics.com/products.asp?cat=83
mscoffman
Do magnetic fields really bunch up at a point like this? The whole
purpose of a magnetic field is to spread out evenly. The first thing
someone should try is to show that this actual happens in using a
triangular magnet and one of those iron filing screens or iron filing
liquid. Magnetic fields don't self focus. It seems they would bunch
up on the trailing edge of the triangle.
:S:MarkSCoffman
