Magnet motor in Argentina
Started by Jdo300, March 19, 2006, 12:46:30 AM
Feb2006
thers no spring se my previosly message its up and down like this.
Feb2006
its a slanted ramp thats pushing down no spring.
Duranza
Quote from: Feb2006 on March 31, 2006, 11:36:47 AM
Thers no spring in the construction thers only a spring effect when the arm is lowerd
against the rotor magnet.
"AL ALCANZAR ESTA POSICION EL BRAZO ELEVADO ES LIBERADO Y BAJA POR EFECTO DE UN RESORTE MIENTRAS EL BRAZO INMEDIATO POSTERIOR ES ELEVADO"
When REACHING THIS POSITION The HIGH ARM IS RELEASED And LOW BY EFFECT OF MEANS WHILE The LATER IMMEDIATE ARM IS ELEVATED
The arm thats going downvards is pushed down by a ramp abowe it.
take a look att the picture
Sist. de descenso controlado =? downward controle system
Do you see it?
Its so simple.
"Resorte" in English means Spring.....
The only way to Validate is to Replicate!
Duranza
So the sentence goes like this : When REACHING THIS POSITION The HIGH ARM IS RELEASED And LOWERED BY THE EFFECT OF A SPRING WHILE The LATER IMMEDIATE ARM IS ELEVATED
Omnibus
Do I understand you correctly? The large black dot is a cross section of a bar immovably attached to the rotor. In your picture it goes from right to left. In its motion it gets under the bevel of the triangularly shaped stator magnet (lower left picture) and as it progresses lifts the magnet up (lower right picture).
Each one stator magnet has a smaller magnet on top (the smaller black dot) which after the stator magnet has been lifted, suddenly meats an iron ramp of a particular profile (upper left picture), sticks to it by magnetic attraction which has nothing to do with the main magnetic interactions driving the motor and then, sticking, follows the profile of the ramp until the stator magnet is brought down (upper right picture).
