"Tiny Orbo Replication" over 100% efficiency
Started by PaulLowrance, January 27, 2010, 12:17:55 PM
Paul-R
Quote from: PaulLowrance on February 01, 2010, 01:07:40 PM
I received my Enermax Marathon PC fan that according to the ebay ad is supposed to be "friction-free" due to magnets.  What a waste of $8!  -->
http://globalfreeenergy.info/2010/02/01/enermax-marathon-pc-fan/
Magnetic bearings are standard issue in some industries:
http://www.skf.com/portal/skf_rev/home
It may be that there are minimum shaft speeds for good operation
PaulLowrance
Thanks for the link. Those are active magnetic levitation  bearings. Do you know where to buy passive magnetic levitation bearings?
Btw, the ones in the $8 fan are by now means magnetic levitation bearings. It's just a marketing stunt.
One idea is to just get a ring magnet where the magnetic field goes inward, and get another another smaller ring magnet where the field goes outward, place the smaller ring magnet on a plastic rod, make another inner / outer ring magnet and place that at the other end of the rod, and you have a passive magnetic levitation bearing!  :)   Problem is, where do you buy such ring magnets.
PaulLowrance
gravityblock
Quote from: PaulLowrance on February 02, 2010, 11:18:12 AM
I found these ring magnets in the automotive section at Wal-mart. It is packaged as a 6" magnetic parts tray with a rubber case to protect the magnet and to prevent marring of surfaces, for less than $6.00 each.  The ring magnets are axially magnetized.  You still need the smaller ring magnets, but it shouldn't be a problem to find some to match the dimensions of these larger ring magnets.  If it doesn't work, then you'll have the ring magnets for other projects.
GB
neptune
There are loads of cheap ring magnets from the magnetrons of old microwave ovens . Always short out/discharge the high voltage cap  before working on microwaves.
