What about Tesla’s Radiant Energy Receiver ? (easy way to get energy from space)
Started by sigmaX, February 05, 2010, 06:10:22 PM
energia9
Quote from: Dogs on April 04, 2012, 03:57:34 AM
I recently revisited the data on Tesla’s Radiant Energy Receiver recently.
I think that an important aspect of the invention is missing from current attempts at duplication.
That aspect is the fact that the energy will really show up when the collector plate is negatively charged.
That subject is covered well in the following video...
http://www.youtube.com/watch?v=geYfUHh6nD8
It seems, back then, an electrophorus was used to make the plate negatively charged.
So, I tried to think of ways of negatively charging the plate.
I looked into what causes static electricity and  turbo electric materials...
Rabbit fur tops the list on the positive charge side.
Teflon tops the list on the negative charge side.
It seems that a good solution would be to coat the plate with possibly a spray/paint Teflon that is a negative turbo electric, and it will act as an insulator for the collector.
Next, place some rabbit fur on a disk, and use a small motor to spin the disk over the Teflon coated area.
This should bring about a strong negative charge to the collector plate. Which will coax larger amounts of radiant energy into it which will then release into the capacitor.
This set up kind of reminds me of the Teslika device.
If it works, the amount of energy required to run the motor that rubs the rabbit fur on the collector plate will be much less that the incoming rush of energy from the environment.
Hmmm...  ???
You are perfectly Right!
http://www.youtube.com/watch?v=P7VN6B2GjVI
****BLESS ALL****
Dogs
Quote from: energia9 on April 05, 2012, 07:57:03 AM
****BLESS ALL****
Thanks energia9.
Here is an optimization on the idea...
Rather than using the rabbit fur. Use a pin-forest that emits negative ions on one side of the plate.
Use a pin-forest that emits positive ions on the other side of the plate.
Use digital switching to control the appropriate application of positive and negative charges to the collector plate.
The negative charge pulsing primes the plate creating a vacuum.
The positive charge pulsing starts the ionic avalanche of energy into the collector.
As I understand it, it can be difficult to control a large in-rush of radiant charge.
Maybe this design would allow for greater control.
hmmm... time to start experimenting...  ???
Dogs
I came across the following patent...
Solar Irradiance Inductive Expeller...
US 2010/0006133 A1
- Claims 60% and more Efficiency.
- Not PhotoVoltaic.
- Collectors are bathed in ionized zones.- 4 to 5.5 percent of obtained solar energy go to  self-supply for feeding exciting coils, electrostatic ionizers, primary coils for transducers, antenna, solenoids' servos, electric battery charging, and various losses.
http://www.google.com/patents?id=Y3XLAAAAEBAJ&pg=PA7&dq=7053576&hl=en&sa=X&ei=VmOCT6zXIbD9iQKE3t2fAw&ved=0CDcQ6AEwAQ#v=onepage&q=7053576&f=false
Seems to me like a highly optimized Radiant Energy Receiver.
Cool stuff...
hacko
I think that the key of free enrfy is in the ions. Radiant energy receiver receives ions. Henry Moray says that it is ions not electrons.
