Ambient rotating magnetic fields!?!?!?
Started by jkgulick, February 09, 2010, 06:15:40 PM
jkgulick
What's going on here?  I was testing the polarity of a magnetic foot brace today by hanging it from a thread and the darn thing just spins around going faster and faster until it is stopped by the tension of the thread.  Then I tested other magnets, and if the mass is enough to keep it from being pinned, the darn things just keep spinning faster and faster.  I tested this all over the house and there are no motors running or anything.  What could be causing this?  If I had a good bearing, the things would just keep turning.
I would like to hear if this is the case for anyone else.
Best regards,
Josh
brnbrade
Hello
turn to diodo and  go to gnd
Gnd salt water and earth.
forest
Can you post a picture or schematic how you did it ?
sparks
    How bout a compass or magnometers (vertical compass).  The Earth nearfield is generated by magnetohydrodynamic flows in the mantle.  Your area may be in the center of a whirlpool down there.  The compass had to be abandoned for navigation because of what you are experiencing now.  The bermuda triangle I am sitting on the edge of has the same problem.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Anothertruthfinder
hi @ jkgulick ive done that one before and been puzzled for weeks then i found out it was the thread causing spin -  i used neodymium magnets and tried a piece of stainless steel on thread and that did the same thing. I also tried making a smooth slip ring type principle add- on and no spin it just locked into the earths mag field like a compass would - i think that is what is happening by the sound of it,
eel
