Thanks to ALL for your help!!
Unified Gravity and Magnetic Generator Principle
Started by onthecuttingedge2005, February 17, 2010, 06:53:35 PM
AB Hammer
Here you go Jerry, and all
I will start a string on magnetic manipulation on magnet motors as well.
shielded magnets from attraction
http://www.youtube.com/watch?v=d0d_wTHPvy0
shielded magnets from repel
http://www.youtube.com/watch?v=5oqH4F_PNjs
total_repel.AVI
http://www.youtube.com/watch?v=jmPd3AOfsDw
total_repel3.AVI
http://www.youtube.com/watch?v=v62E_cNeOJI
Several simple test can lead us into a better direction. May these help.
With out a dream, there can be no vision.
Alan
Quote from: AB Hammer on February 21, 2010, 11:41:41 AM
total_repel.AVI
total_repel3.AVI
Thanks AB.
since I was already subscribed I saw them as they came out.
AB Hammer
Quote from: onthecuttingedge2005 on February 21, 2010, 11:50:35 AM
Thanks AB.
Jerry
Don't forget to give me some ratings please.  ;D
Alan
Rapadura
Sorry to repeat here what I already posted in this other thread:
http://www.overunity.com/index.php?topic=8532.0
But it's important... Jerry, I think that maybe I  found an answer to our problem of "popping the ball away from the magnet once it gets to the top", in the words of someone who commented on this video of your French friend:
http://www.youtube.com/watch?v=Kp-KYiTwtRo
My idea is: what if the magnetic ball is not a neodymium ball, but an electro-magnet?
Yes! The ball may have a very small battery inside it, and it can be an electromagnet!
We may have some intelligent control system that, when the ball reaches the top, reverses the polarity of the ball! We can imagine what happens when a powerful neodymium magnet encounters an electromagnet that has the same pole turned to its face!
The main advantage over the idea that I gave before (the last magnet being an electromagnet) is that if the ball is the electromagnet it don't need to be very powerful, and a small battery easy to recharge after a few loops would be sufficient.
you have to keep the magnetic gradient smooth on the up side, the magnets must be thin to keep the bulk of the step array small, 0.05mm or thinner, try to keep the vertical array at least 3 meters high or higher, the higher you go the thinner the magnets have to be to keep down the bulk. use NEO's to help keep good magnetic field strength. since magnetic acceleration will be stronger on the magnetic side you could generate more electricity on the magnetic side, as the magnetic ball falls on the downfall side it will have less potential because Gravity is a lessor force than magnetism. but returnable!
