Magnetic amplification and neutralization motor by Art Porter
Started by LarryC, February 20, 2010, 05:07:38 PM
LarryC
Check out this motor at  http://www.gap-power.com/. The video's take a while, but worth viewing as the concept is fully explained. Found this info at Peswiki.
This motor is much more powerful than Orbo and no secrets.
Regards, Larry
Magluvin
Watched the whole clip. Seems very interesting. It would have to be made to ways to convince me though.
1 would be as shown, and the other would be with just coils and cores.
What I question is, if the coils were used to push and pull as compared to pull and cut off, there may be equal forces to the rotor either way.
Like speaker systems for example, 1 10in speaker at 100w lets say can put out 100db at 60hz. If we now have 2 speakers at 50w each and 60hz, we will have 103db, at the same power.
The way this works is, 1 speaker at 50w and put out 97db, if the power is doubled to 100w we get a 3 db increase.
But if we introduce a second speaker at 50w along with the other at 50w, the increase is 6db.
Sounds hard to believe a bit. Increasing output wattage, per say, to double by dividing the input power to 2 motors
and combining the outputs.
And if we have 4 speakers at 25w ea. the total out would be 106db.
This doesnt say much about the efficiency of the original speaker. Now we add a tuned port to the enclosure. At the tuned freq the db increase could be above 10db, This type of increase would require 10 times the original input power.
All in all, I have tested this with the speakers and it is true. As for this motor, it would have to go though the suggested test above to say if this idea works or not. If the motor as presented were 100% eff. and the 1 without perm. mags were 95% then I would say he has the advantage.
I wonder if the guy is still around, and if he could do these tests.
Mags
ramset
Larry
I watched the entire sequence also,
Seems like a really cool idea [magnets as batteries] a very simple concept with a very big payback [amplification and neutralization].
Do you know of any attempts?
are you considering one??
You always do such great  builds it would be nice to see one that could make as much power as this one would seem to be able to do[linear power curve]
It seems that one could rip" Hell off its hinges" with one of these motors!
would be interesting to know amps on these coils[I know depends on mag strength],as the "pulse" would be infinitesimally short[back and forth]but always on?
Very cool Larry
Thanks
Chet
Thanks Grandma
Omega_0
Quote from: LarryC on February 20, 2010, 05:07:38 PM
Regards, Larry
Note that he is not claiming OU.
It is a very efficient motor. 95% saving is cool. However he should show the power consumption under load. Without such tests we won't know the actual savings.
Anyway good presentation.
ramset
Well...............
I just have to ask
If I can provide a constant 1000lb "pull" on a wheel with this set up ,
How the heck do you calculate OU[or any] efficiency utilizing ten 100 lb [pull] magnets as part of your power curve?
Thanks
Chet
Thanks Grandma
