Magnetic amplification and neutralization motor by Art Porter
Started by LarryC, February 20, 2010, 05:07:38 PM
alextecmen
I changed the bifilar coil for a bigger one, more wire, 2020 turns, wire 23 and 26, I used them in a bedini motor.
The result was that I did not turn on the 12 volt car light, I put a 75 watt incandence light on it, and the coil was powered with 60 volts, and it turned on 1/3 of its illumination, plus resistance plus voltage to power generate the back fem, but the way is not there to increase the voltage, of course I still do not have the appropriate signal generator, but I wanted to experiment.
The task is to replicate Mr. Porter, in a functional and practical way. Is it possible? Are the results true?
Around here one tries to achieve it or obtain some good energy.
Has anyone of you tried it? I have achieved good results
As always, I appreciate your comments and contributions
synchro1
here's the Arduino and a Hall effect sensor; this detects the magnetic field peak. the ground to gate p channel reed, the collapse.
the hall for top dead center power and the p channel for neutralization.
alextecmen
Okay. Thanks, I'll check it, but the arduino has to be programmed
alextecmen
Today I found the signal generator, I am going to have to adapt the power circuit to it, since I have it I can control the relay, or through transistors or mosfet, so I have some work, I want to try first in this way with the generator, and then I will do tests with what they have shared with me about the arduino control
alextecmen
Greetings
Continuing with the work, I got up early today to assemble the power system of the salts generator, since yesterday I went to buy the components, taking advantage of the time that I have free, since one stops working due to family tasks. In what he likes, to carry out his hobbies, experiment, make prototypes, good at research is coil, and we do it according to our disposition of material and economic resources, and to our knowledge, perhaps most do not have a laboratory, but If you have a lot of desire and talent to discover new alternative sources of energy or improve them, adapting them etc.
The coil power management device was simple, a BC558 transistor, two resistors, and a tip 41 transistor, and connection cables.
Once assembled and connected to the signal generator and the coil, and the 12 volt bulb (BEMF pick-up element), the signal generator was fed with 12 volts, and the power or output device 33 volts.
Once everything was in operation and I turned on the circuit, and as the frequency increased, the bulb began to shine at 130 hz, and its brightness improved by increasing it to 270 hz, more light was achieved in the bulb, but the duty began to increase. signal and much improved the brightness of the photo
Increasing the frequency gave an increase in brightness but going from one range to another, for example 270 hz, at 370 hz, the brightness was increased, but every 100 hz of increase the increase was less and less, that is, if it increased but but less.
I also tested with change in duty signal, the brightest range was obtained from 1.65% to 1.70%, at any frequency.
Increase the frequency to many cycles above 1khz and more, there almost no longer any perceptible changes in the brightness of the bulb, what if it is advantageous at high frequencies is to avoid the hiss or hum of the frequency.
In testing and making changes to other tests, the tip 41 transistor was damaged 3 times, in one because I turned on the coil without the capacitor bulb, and the BEMF struck the transistor.
I read applied voltage, amperage drawn by power element (magnetized coil).
The bulb is 12 volts, 21 Watts, in some of the readings 32.46 volts was applied, with a consumption of 0.52 amps which gives us 16.8 watts, the brightness of the bulb is at 90 or 95 of its total brightness.
By varying the frequency, duty had either an increase or decrease in current, increase or decrease in voltage, but in average terms, the 0.52 was the most repetitive.
Tomorrow if I have more time I will give you images of the reading.
I'm also going to try motfet transistors.
The coil used does not yet have the specifications that Mr. Art Porter proposes, I will make one according to your specifications, measurements, coil resistance, magnets, and the core.
From what I have commented, we welcome your comments and suggestions.
