Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
e2matrix
It would appear this company has proven OU with a magnet device: http://www.terawatt.com/index.htm
Underwriters Laboratories tested as well as others show less than 200 watts in giving over 600 watts out.  They have a plan to put this into production but their time table is a lot slower than I'd like to see.  If my experience with another technology is any indication I'll bet China will get such devices rolling off the production line a lot faster.
   I'm not putting a lot of faith yet in Magnacoaster but this Terawatt company seems to have a lot of credentials and valid scientific testing behind their product.  That tells me more than much of what I've seen that Lawrence's theories will work.
NerzhDishual
@Itseung888:
Thanks a lot for having spending time explaining your views. It is very informative.
Lead Out = Bring In. This is more clear to me.
The native French speaking persons are not very comfortable with composed words.
In English language (and in Chinese one, I guess) it is a common process.
But, you are preaching to the choir!
I'm not a skeptic and  I think that (any extra) energy is not created out of nothing but
merely harnessed from known environment (heat pump, solar panel, pendulum?, etc..) or (still) officially unknown one.
Thanks again and Very Best
ltseung888
Quote from: NerzhDishual on April 19, 2010, 04:49:28 PM
@Itseung888:
merely harnessed from known environment (A, A, pendulum?, etc..) or (still) officially unknown one.
The term "lead-out" was first used in our PCT patent application.  We stated that we needed to supply some initial energy to start the process.  We also stated that in the absence of controlled feedback, we needed to continuously supply some input energy to "lead-out" or "bring-in" gravitational or electron motion energy.
The pendulum calculation was disclosed in the patent application. PCT/IB2005/000138
ltseung888
Quote from: ketone on April 19, 2010, 11:45:15 AM
Good Summary!...i am in agreement working on a similar A setup...
You are on very solid theoretical grounds.  Continue to hunt for the best resonance situation to lead-out the maximum energy with your particular setup.
nul-points
hi Nerzh
LOL @ the 'Underunity Fine' - c'est magnifique!
i'm not sure from your info if you were able to view the output waveforms - or are the voltage readings just from a DVM?
if the readings are just from a DVM then it's possible that they do not give you true RMS values for power & therefore energy
but i agree with your summary: we are searching to see if it's possible that pulse spikes can 'trigger' a battery to take on more charge (from the environment?) than is supplied as conventional energy from the source?
we need some 'solid' results with battery discharge tests after charging runs (on an initially discharged battery)
a couple of interesting items of recent 'synchronicity':
- on the JT thread, one user (tysb3?) has been recording running battery voltage over several days & the data also clearly shows that the battery voltage increases with the daily temperature cycle
  this reminded me of your temperature tests with those caps/condos
- then this weekend i was checking the off-load voltage of a 1 Farad cap around midday, in a very hot (eg ~40*C) sun-heated room and instead of self-discharging slowly as usual, the voltage rose 16mV with the heat
   this was 'real' energy which i was able to drive my low-power circuit with that evening for a few hours before the voltage discharged to its previous pre-heated value
i hope that since Lawrence has introduced the subject of Joule Thief to this thread that our JT discussion here will not be seen as too much off-topic
greetings from the land of 'ros-bif' and warm biere!  A+
sandy
