Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
ltseung888
Quote from: Paul-R on May 29, 2010, 10:21:21 AM
Put an ammeter in series with your toroid, a resistor of some sort and a signal generator.
Set the sig-gen to 0.
Wind the sig-gen up whilst watching the ammeter.
You should notice the needle go down, pause at its minimum, and as the sig-gen
is increased further, the needle will increase.
The frequency at the minimum will be the resonant frequency for that LR circuit, noting
that the figure depends on the value of your safety resistor. You will need to change
this resistor for something nearer in value to the resistance of your actual circuit, and
then repeat the performance. Have a glance at this:
http://www.allaboutcircuits.com/vol_2/chpt_6/5.html
Paul-r
Dear Paul-R,
Thank you for your excellent input.  I also found a similar technique when applied to my Joule Thief type circuits.  I used the signal generator in place of the battery.  The brightness of the LED varied with frequency.  There were "sweet spots" showing characteristic resonance behavior.  At certain frequencies, the LED was much brighter.  The LED turned dimmer when I changed the frequency below or above that certain frequency.
I believe I can get my Joule thief circuits to demonstrate overunity.  The Lead-out Energy theory predicts that.  The bright LED spots seem to have lower input power (lower voltage and current) while the output power (both voltage and current) increased.  I shall get some better equipment to confirm the above results.
Paul-R
I think we should avoid digital meters.
Don't forget that the ammeter has a resistance which should be
added in.
It might be better to remove the ammeter in series and instead
measure the voltage across the resistor.
(There is such a thing as a Grid Dip Oscillator but I have no idea
how it works).
Paul-R
Don't forget that this technique works for the driving coil but not the others.
The other coils on the toroid, containing probably R elements along with
I and C ingredients, will need to be tuned to the frequency already established
by having their R, and/or I and/or C varied.
ltseung888
请把下文上ç½'在å'表. (æˆ'å·²å'表在天涯问ç­")‏
Sent:   Wed 6/02/10 5:57 AM
To:    Lawrence Tseung
倍受å...¨çƒç§'学家å...³æ³¨çš,,王沈河å'明çš,,"微动力å'ç"µç³»ç»Ÿ"在世博期间圆满中试成功!"
微动力å'ç"µç³»ç»Ÿ"系采ç"¨åœ°çƒåœ¨å...¶è‡ªè½¬è¿‡ç¨‹ä¸­æ‰€äº§ç"Ÿçš,,一种动能!  可通过"微动力å'ç"µç³»ç»Ÿ"直接转换为ç"µèƒ½!  并可直接为需要ç"µåŠ›çš,,系统源源不断çš,,进行è",,ç"µ!
å...¶"微动力å'ç"µç³»ç»Ÿ"çš,,å'明成功真实çš,,添补了ç"µé©±åŠ¨ç›´æŽ¥ä¾›ç"µçš,,国é™...空白!
系末来ç"µé©±åŠ¨æ±½è½¦ã€é£žæœºã€ç«è½¦åŠèˆ¹èˆ¶ã€æœºå™¨äººç­‰æ‰€ç†æƒ³çš,,ç›´å......式供ç"µç³»ç»Ÿ!
ç"±æ­¤å¯è§ä¸­å›½å°†åŠ å¿«è¿›å...¥ä¸€ä¸ªæ— ç¢³æ—¶ä»£å·²æˆä¸ºçŽ°å®žï¼
The above is a request from Mr. Wang Shen He.  Those interested should email him directly.  He is answering question in Chinese at the Chinese language forum 天涯问ç­"
ltseung888
微动力å'ç"µç³»ç»Ÿç®€ä»‹
本å'明(ä¸"利号:201010193076.20)系成功采ç"¨å››å¤§åЛ䏭çš,,二大力即ç"µç£åŠ›ä¸Žå¼•åŠ›ã€,通过å...¶ç‰¹æ®Šæœºæ¢°ç»"æž,,成功çš,,把微动能提取转换为动能,在ç"±åŠ¨èƒ½ç›´æŽ¥é€šè¿‡å...¶åŒ¹é...çš,,通ç"¨å'ç"µæœºç»,,转换成ç"µèƒ½ï¼Œç"±æ­¤è¯¥ç§å¾®åŠ¨åŠ›å'ç"µç³»ç»Ÿå¯æºæºä¸æ–­çš,,在动中取能,并直接转换成ç"µèƒ½ï¼Œä¸ºç"µé©±åЍè",,ç"µç"¶æºæºä¸æ–­çš,,进行è",,ç"µï¼Œå‡ ä½•式çš,,增大了行驶里程ã€,确保了一次å......ç"µä¸‡é‡Œè¡Œç¨‹ã€,
现通常开å'çš,,ç"µé©±åŠ¨è½¦è¾†ç­‰å‡ç³»é‡‡ç"¨å......ç"µè®¾å¤‡ï¼Œä¸ºå...¶ç"µé©±åŠ¨è½¦è¾†ç­‰è",,ç"µç"¶è¿›è¡Œè¡¥å......è",,ç"µã€,但行驶里程因è",,ç"µç"¶å®¹é‡å—限,为了解决这个问题,不得不在è",,ç"µç"¶ç"µèƒ½ç"¨å®Œå‰å†æ¬¡è¿›è¡Œè¡¥å......,ç"±æ­¤è€Œåˆ¶çº¦äº†ç"µé©±åŠ¨è½¦è¾†ç­‰çš,,连续行驶里程,并急需建立大量å......ç"µç«™ï¼ŒæŒç»­æ¶ˆè€—了能源,却没有采ç"¨è£...载在通ç"¨å'ç"µæœºç»,,上çš,,微动力å'ç"µç³»ç»Ÿï¼Œåˆ©ç"¨å¼•力在动中取能,ç"±é€šç"¨å'ç"µæœºç³»ç»Ÿç›´æŽ¥è½¬æ¢æˆç"µèƒ½ï¼Œåœ¨è½¦è¾†è¡Œé©¶ä¸­æºæºä¸æ–­çš,,为è",,ç"µç"¶è",,ç"µæ¥è§£å†³è¿™ä¸€é—®é¢˜ã€,
本å'明经è£...载在ç"µé©±åЍç"µåŠ¨æ±½è½¦ä¸Šä¸­è¯•ç»"果证明该种微动力å'ç"µç³»ç»Ÿå¯æºæºä¸æ–­çš,,在ç"µé©±åЍç"µåŠ¨è½¦ç­‰è¡Œé©¶ä¸­èŽ·å–åŠ¨èƒ½å¹¶å¯ç›´æŽ¥è½¬æ¢æˆç"µèƒ½ä¸ºè",,ç"µç"¶æºæºä¸æ–­è¿›è¡Œè",,ç"µï¼Œå¯å¹¿æ³›çš,,匹é...åº"ç"¨äºŽä¸€åˆ‡éœ€è¦ç"µåŠ›è¡¥å......çš,,ç"µé©±åŠ¨è½¦è¾†ã€å†œæœºã€èˆ¹èˆ¶ã€èˆªç©ºå™¨ã€æœºå™¨äººç­‰ï¼Œæ›¿ä¹‹ä»¥å...¶å¿...须停机å......ç"µè®¾å¤‡çš,,微动力å'ç"µç³»ç»Ÿã€,
王沈河
è"ç³»ç"µè¯ï¼š86-15911058895
Email:wshsdfm200808@126.com
The above is from Mr. Wang Shen He.  Please contact him via phone or email directly.
