Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
ltseung888
The more professional looking prototype
Aaron and I went to Hong Kong University and met with Prof. Dennis Leung.  We presented the two prototypes targeted for USA.  The first one was the best configuration built by Tseung with COP = 195 and Output Power = 12 watts (peak-to-peak).  The second one was built by Aaron on a circuit board with COP = 129 and Output Power = 1.5 watts (peak-to-peak).
Prof. Leung: “I can see the results on the oscilloscope.  They are not hoaxes.  However, I would like to use our own oscilloscopes and data loggers to do additional verification and confirmation.”
Tseung: “We can build one for you right now in your laboratory.  We need to do that in the Oct 9 workshop in any case.  Would you like the quick version or the professional looking version?”
Prof. Leung: “The professional version.”
Aaron then spent a couple of hours building a professional version for Hong Kong University.  The variable resistor should be 100 ohms.  But we did not have that in our possession.  We then used the 1K ohm version knowing that it might affect the performance.  Sure enough, the device worked but with a COP = 5 only.
Aaron: “I shall have a batch of toroids, variable resistors etc. from Shenzhen tomorrow.  I shall build a better one for Hong Kong University in the next few days.”
Tseung: “Can you build at least 2 good-looking ones for me for USA?”
Aaron: “I may try a mass production version for your Book.  Remember that I am an Industrial Design Engineer.”
The decision is to show and leave the good-looking ones for the Universities.  However, in the workshops, we may do the quick and dirty version.
ltseung888
From the Joule Thief Thread:
        One guy tuned the output of a Joule Thief to resonate an ignition coil... that lit up 2 CFLs at Resonance.
        This guy is brilliant  !!!
        I believe this is the direction to go...
        as one might gather from my
                               (((((Why is an Acoustic Guitar louder than Electric Guitar ?))))) Thread.
                                                       I assert here quite heavily
                                                 against a stiff wind of opposition
                                             that Resonance is a Phenomenon that
                                       deserves A LOT of attention in an OU Forum.
In short, if you are just getting to know me... I say there are 2 legit sources of Free Energy I can see.
             1. Ferromagnetics... that utilize free electron spin magnetic dipoles.
             2. Forced Resonance... Two tuning forks ring louder and longer than 1 when only 1 is struck.
Best Regards,
                     The Observer
Dear Observer,
I think you made the very important point here.  Energy can be lead-out or brought into the system with
Ferromagnetics and forced resonance.
I just built another prototype for US using the commercially available 1 inch choke.  I put the JT winding on top of the existing winding.  After much tuning, I got it to produce 0.4 watts and COP = 8 (peak-to-peak).  It could demonstrate overunity but was nothing close to the Output = 12 watts and COP =195 prototype.
I shall focus on producing a number of “identical best” prototypes for the academics in Hong Kong, China and USA.  The goal is for them to verify and confirm overunity.  Providing instructions and using similar material are not enough to produce high performance prototypes.  Small changes make big differences in the resonance world.
ltseung888
The Pendulum Toy for USA
Lee: “Are you bringing the Pendulum Toy to USA and use it to illustrate leading-out of Gravitational Energy?  People may laugh at you.  The toy has been around for years.  They will not take you seriously.”
Tseung: “Many scientists already wondered why so little energy was required.  Some of these toys produced pretty loud sound at the end of each swing.”
Chan: “As I understand it, the Lee-Tseung lead-out energy theory can be explained via the physics of horizontal and vertical work.  Normally, a horizontal force cannot do vertical work unless a machine is involved.  In the case of a pendulum, a horizontal pull will raise the pendulum bob.  Some will attribute that to some kind of pulley type machine system.  Lee-Teung theory explains that the vertical work is done via the tension of the string.  That part cannot be disputed.  The part under dispute is â€" the energy to do the vertical work comes from Gravity.  Is that correct?”
Lee:” Correct.  The Lead-Out energy does not violate the Law of Conservation of Energy.  It just brings energy from the surrounding.  The horizontally pulled pendulum leads out gravitational energy during the pull.  Thus the best time for the pull is when the pendulum is at its maximum displaced position.  The frequency of the pull (or the pulse) is extremely important.  It can be thought as a resonance behavior.”
Tseung: “I do not mind showing the simple toy.  Toy manufacturers are already using lead-out energy without realizing it.  Scientists and academic professors should look at the results scientifically.  They should not just dismiss the result with the statement â€" it is just solar energy.  Once they understand it, they can understand FLEET.  The FLEET devices to be shown all have COP greater than 100.”
Chan: “You can now mass produce these one-inch enhanced Joule Thief Toroids.  Your results can be confirmed by many on the Joule Thief Thread.  Some of their results are more impressive than yours.  However, you are the first one to propose the two oscilloscope experiment and confirm overunity.”
Lee: “Good Luck.  When you see Todd and Nora, say hello for me.”
rave154
well folks....i guess we really should have anticipated it...
Mickey Mouse for the Lead out Gravity energy
and
Minnie Mouse for Lead out Electrom motion energy
let me jump ahead and see where this might be going.....
Pluto for Leadout String theory positron manipulation Energy
and...the three little pigs for for any other idea/s that come along that can possibly be shoe-horned into "Lead Out" theory
The Observer
Tseung,
You said...
All I can say is...
Now We're Talking !
Why don't you try...
1. A Joule Thief tuned to resonate an Ignition Coil. (lights a CFL)
2. A Joule Thief tuned to resonate 2 Ignition Coils (identical coils with Identical Resonant Frequencies).
3. The output of Coil 1 going into the Input of Coil 2 from suggestion #2.
4. Find out how many Ignition Coils could be resonated by a single Joule Thief?
You're going to need to light up some CFLs with a 1.5 V AA.. if you are going to really impress anyone on your trip.
The JT/Ignition Coil method seems like the simplest and most demonstrative of Resonance coupled with Ferromagnetics.
Best Regards,
                    The Observer
