Electrical igniter for gas engines A keystone to understanding by Magluvin
Started by Magluvin, March 01, 2010, 01:30:50 AM
Dave45
Quote from: Magluvin on April 18, 2011, 08:11:28 PM
Hey Dave
Are you baring gifts?  ;]
Mags
Just a hunch, brass wire should exhibit negative resistance because of the zinc content.
Magluvin
Very Nice Woops!!.
It appears that being the steel ball makes it ALL the way across the S mags, and past the N, I wonder if 2 N will have the same pull once crossing that line.
By the way, Im not putting restrictions as to topic related. As long as they are good, and originated some how from here, its ok by me.
Which pdf was this from woopy?
Thanks
Mags
edited the word into to past
nievesoliveras
@woppy
I saw your three magnets video and I thought that if the ball crosses from positive to negative with the same quantity of magnets added at the left of the first magnet, then you can repeat the pattern around a ring and get the ball perpetually running.
I could be wrong though!
Jesus
Magluvin
hey Dave
Any links?  I did some searches
Brass Wire
Brass Wire Inductor
And so on.  I see some rf applications, of which I noticed something else....
It was talk of aluminum and brass cores.
I wonder what results that would give.  Solid would be a lot of eddys, but powdered into toroid cores, I wonder if there is anything worth looking for.
Im getting some things together to pour my own cores.
But brass wire.
I ended up finding these that should be of concern with our projects.
http://www.token.com.tw/what-is-a-inductor.htm
Woopy. have you noticed if you use higher voltages, that your eff increases, as compared to low voltages like 5v?
I think we can try to make better inductors than ones that we can buy or get premade. Ive seen laminated cores welded across the laminates. This has got to be bad for eff.  But I think we can do better. Ill come up with some schemes of materials and epoxy.
The bifi thing is biting my ear, Make me, make me. Im winding one this week to work with.  I have others but I want low resistance.
The only way to get good current is with a wire that can handle it.
Anyway, Cant find really anything on the brass wire having any special properties that might be.
That might be a good thing. ;]
Mags
