Electrical igniter for gas engines A keystone to understanding by Magluvin
Started by Magluvin, March 01, 2010, 01:30:50 AM
forest
I'm sure that no matter if Earth magnetic field rotate or not (probably not) this magnetic cavitation effect occur.
Doug1
Not sure what he is up to using an inverter but i would imagine if you use one to run a load through a coil you could work it out to function like a JT where it will either store additively up to the battery potential using the 50/60hrtz to charge a second bank with spikes to extend the run time of primary bank. I might be able to toy with it if I can get my wife to send me one of my 5kw inverters and some microwave parts i have boxed up. I had to take this job really far from home for the summer to finish my training.Knew it would come back to bite me in the arse.tweeking it out and getting it fine tuned would be the hard part. If possible it would sure reduce the expense of needing so many batteries in an off grid system. It might even resolve the issues caused by surges from large motors starting up on inverters.
All in all I suspect it will require a transformer of size like one from a welder to handle the power instead of a tiny teroid.
Magluvin
Im not sure what Tito means  a lot of the time.  I cant say that anyone does.
He uses an inverter to get 12v for free.  Send that out there and see how many questions are returned.
He is clever at never telling us anything. Thats why my interest in what he says is very low at this time.
Coil with a tail?  Maybe. But nothing yet.
But Im not about to get an inverter and hook up the output to a 12v battery or any 12v device.. Sounds like advice to put someone in danger. Be careful Doug.
Ram, to put a vid on YT it must be less than 10 min long to upload, and you must have an acct.
Once you have an acct and are signed in, any page you are on will have an UPLOAD icon that will take you to an upload page. From there its easy. You just need to know what folder the vid is on your pc for YT to upload from.
Mags
Magluvin
As for microwave parts,  the transformer, the cap, the diode, and the a/c cooling fan and the micro switches ar the only parts I would recomend removing that are of good use.
I would stay away from playing with  the microwave device itself.  The stuff I mentioned above are all that I had taken from the busted microwave oven, as I never even opened one before, just common sense and reading tells me so.
mags
wattsup
Quote from: forest on April 05, 2010, 08:21:52 AM
Check this theory and following comments :
http://www.energeticforum.com/renewable-energy/4006-rosemary-ainslie-magnetic-field-model-4.html#post65502
What guys with such ideas always forget is that on Earth you cannot be in two fields at the same time. You are either in the north polarity or the south polarity of the Earth but never both. Even in space, if you are hit by a moving field, it will only be one polarity. You do not need or even want the Earths polarities to move against its normal rotation otherwise we would be toast.
Someone recently said you cannot do anything with a rotor having turning magnets with only a single polarity hitting the pick up coils and this has been shown to be not true. It works. Why. If you are in the North field of the Earth, and you pulse only a south field over a pick up coil, at every pulse off, the Earth's North field takes up the space again and you now have both polarities acting on the pick up coil.
The greatest and simplest proof of this is your simple compass. From thousands of miles away, that compass still knows where the North field is originating from. Seems mundane but there is an extremely powerful force there. So imagine all the atoms know this also and regardless of their molecular make up, all atoms will have a preferential orientation towards to the North on the north hemisphere. When you pulse, the atoms realign in the direction of the new pulse source or magnetic field source, then when the pulse is off, the atoms revert back to aligning themselves with the Earth field. Why do you get a kick when the pulse is first applied. Because all those atoms are pointing towards the North pole normal latent state (not so latent after all). At zero applied energy the atoms are pointing North so at the first pulse, the atoms swing towards the new source but at this first pulse there is nothing to hold it back so you get a first dramatic and unhindered swing that gives you that kick. After which the continued on/off conditions of the pulse control each of the further atomic swings.
Tesla's Radiant energy has only one plate in the air. Why only one plate, with the other side in the ground. Because he knows the Earths field at any given point is a mono-polarity. Otherwise he would have used two plates and hoped to hell each plate will catch one polarity. That is one of the reasons we are alive on this planet, because if both polarities were equally available all over the planet homogeneously, we would have all fried a long time ago. We would be living in a constant short circuit state.
I asked Tito a question about how he sees a zener and he answered that he sees it like a cannon/diverter. To me this means charge a cap and at a certain highest voltage discharge it into a side circuit, NOT THE SAME CIRCUIT. Hmmmmmmm.
Also regarding Tesla's Ozone Patent, thus far I have not been able to replicate it using any type of Mosfet. If anyone can, they will get the answer. But if Tito is using this patent as a basis, then he is surely not using mosfets to pulse it, unless of course he has discovered the secret to using a mosfet in such a scenario. But the mosfet HAS TO LET ENERGY FREELY FLOW IN BOTH DIRECTIONS. But thus far all mosfets can do is fry. So if he is using that patent, then he is using some other mechanical rotary method or he is pulsing a relay and he still has the problem of sticking relay reeds, etc. The other method of using a spark gap is simply a major energy waste.
