Electrical igniter for gas engines A keystone to understanding by Magluvin
Started by Magluvin, March 01, 2010, 01:30:50 AM
forest
wattsup
I fully aware of being in one polarity North Earth magnet.
What is gong on with small magnet if you push it against large magnet field ?
As I know it will be catched inside magnetic buble and stick to large magnet with opposite polarities facing towards each other ! What would happen if that small magnet could instantly dissapear ?
There is atomic interaction which I don't quite understand yet which disallow our neo magnets to orientate properly in Earth magnetic field but when it can freely move it will behave like compass needle.
baroutologos
MOSFETs, Tito said, Igniter patent etc.
All those contribute to chaos rather knowledge. In any case, even if the potential source of OU is unknown (if exists at all) in those patent series as indicated that hold the "secret" and all are not about Tito's playing ground thing... (that 99,99 % probably is) i proceed as:
I have obtained a permanent magnet DC motor with carbon commutators.
I am gonna re-arrange (if i can, i think i can) this motor and adapt it to work as the Ozone patent, that is same in operation principle as the ignition patent i guess.
Then i will report.
ps: Little less conversation, little more action..  elvis
ramset
Action?
Action for the sake of action ?[I know NG]
Theory?
Forest Quote:
magnetic cavitation effect
Well not exactly a theory!
http://www.youtube.com/watch?v=eKPrGxB1Kzc
Just a good way to get your mind around it!
Cavitate the medium,"stress the fields"
Pulse, oscillate, agitate, whatever it takes!
Open the door!
Chet
Thanks Grandma
Magluvin
Thanks for the input Watts
Tito had said something about carbon, aluminum and zeners at one point. The zener was what went through my mind more though. I went through many thoughts of what and where we could use it other than just regulating.
The I looked up HV zeners and I thought hmmm, Zener as a spark gap?  And I asked tito if that were the case and he said BIG YES.  But then I had to think, well which type do I go fore to start out? I know Teets aint tellin, hints but only 1 piece to a 6 piece puzzle then its muzzle time.
But, After that Big Yes, he comes back with he does not use the zener anymore. Something better. But of course tell everyone zeners and such but its not what he uses, Of course.  Well yippy. :-\
But as I thought about it in the back of my mind, the drawing that tito put up for Stefan long ago and is reposted here or Magnifier thread of the 200v/24v transformer with the relay and a cap and diode across the contacts, well there is a post before that describing and he says dont forget to use a zener diode. And I can only assume he meant the one across the contacts and a resistor in series, and he says use 3v or higher.
So if the zener is 3v per say, and we want the cap to hold a high voltage, the zener will keep that voltage low either direction, no? Forward bias and reverse.
Now, could the zener function just be for protecting the contacts? Or does this diode WITH a resistor in series with it, be some kind of valve that lets the current from the coil move slowly thus helping some how to keep the current flowing longer?  He was claiming it to be the secret of the SM TPU at the time.
Remember, this is just all the thoughts that I have had ever since. Some of it may be laughable, as I have chuckled my self, but these are thoughtful possibilities.
mags
bboj
I also thaugt about this zener. It could be used at the end of the "tail" coil. If you look in Colorado Springs notes, you can arrange some kind of capacitance to store energy of the extra coil - capacitor, isolated coil, coil made of coaxial cable or even batery. It should be connected at the end of the coil between capacitance and the final part of the coil so you get only a part of the energy needed to switch the diode which is small enough to not disturb the resonance. But I have to study some more
