LaFonte Group can turn off permanent magnet without work
Started by Paul-R, March 03, 2010, 06:31:34 AM
mscoffman
Hi, Butch;
Any chance that this could be retrofited into an existing
automobile alternator coil and body for experimenting?
I think it will have less energy density per weight and
unit volume then normal generators...but with a
distinct advantage.
Where is Mr. Tesla in all of this...He said there was another then
current unknown "wheel" in electrodynamics, one that could enable
free energy...But he didn't say one could achieve it by adding
a metal ring into the rotor position of one of his generators.
:S:MarkSCoffman
Butch LaFonte
Hi guys, I will be back in about three or four hours to answer any questions and reply to comments, But in the mean time I wanted to mention something. The switcher is a product of 5 people's work, Myself, Mark, Nicolas, Lawrence and Bruno. It's being referred to as the LaFonte Switcher but it is really the LaFonte Group Switcher.
I don't want all the credit to get attached to me. We work as a team and everyone has stuck with me through all the designs that did not work and I am very lucky to have such a great team. We don't know how many machines we built that might be overunity because we ran out of money before R&D could be completed. Mark has a storage trailer full of our prototypes. Maybe someday we will have the funds to complete the R&D on all of them. There are close to 2000 designs on paper. Maybe with the success of the switcher we can build them all.
Back in several hours,
Butch
Bruce_TPU
Hi Butch,
I have a little different way than Stephan.  Simply leave out the activated charcoal.
My iron oxide was purchased on Ebay...very cheeply!  LOL
I hope this helps:
DIY:
http://www.youtube.com/watch?v=hnY1Zbi7sgM
Cheers,
Bruce
Butch LaFonte
Quote from: Bruce_TPU on March 24, 2010, 07:33:58 PM
Hi Butch,
I hope this helps:
DIY:
Cheers,
Bruce
Bruce, Could I ask a favor of you? Could you put the leads of an ohm
meter about an inch apart into a pile of iron oxide to see what the
resistance is? This is without the charcoal.
Thanks, Butch LaFonte, The LaFonte Group,
Bruce_TPU
Quote from: Butch LaFonte on March 24, 2010, 10:16:43 PM
Hi Butch,
It oscillated between 10 and 11 M   ohms.
I hope that helps you out.
Cheers,
Bruce
