LaFonte Group can turn off permanent magnet without work
Started by Paul-R, March 03, 2010, 06:31:34 AM
Butch LaFonte
Bruce, did they give you any info on the exact type of black iron oxide they sold you?
I believe there are 3 maybe 4 different compositions.
Thanks so much for the test. Thats a lot of resistance.
Butch
onthecuttingedge2005
the problem is quite congruent, if you are not using superconductive material then you will have losses. simple as that!
gravityblock
Quote from: hartiberlin on March 23, 2010, 03:30:51 PM
This is really a great new design.
I guess it will be a winner
and it is a real good dragless generator.
Looking forward to see it realized in real hardware.
Don´t build it too small, so the magnetic losses
and hysteresis losses will not kill all the output.
Many thanks.
Regards, Stefan.
The Perminvar alloys have constant permeability and almost no hysteresis up to flux densities of 1,000 Gauss. Even at still higher flux densities, residual magnetization and coercive force remain practically zero.  The permeability of Perminar, however, remains constant only as long as high magnetization is avoided.  Other materials which have constant permeability are Conpernik, Isoperm, and powdered irons.  These materials have a near 0 hysteresis loss
The above information can be found on the 12th page of the "Survey, Characteristics, and Evaluation of High-Performance Magnetic Core Materials" by the United States Airforce, http://www.overunity.com/index.php?action=downloads;sa=downfile&id=381
GB
Bruce_TPU
Quote from: Butch LaFonte on March 25, 2010, 12:40:01 AM
Butch
Hi Butch,
No, simply Black Iron Oxide Powder.  It is very fine.  If I recall, there were some that were larger grain.  I tried to find the finest particulate.  I hope that helps.
