IST RING OF POWER
Started by innovation_station, March 05, 2010, 03:28:51 PM
innovation_station
here is a video of the coil i wound for the base charger for the ring stack ..
this is the ALI coil
W
http://www.youtube.com/watch?v=s95te2vP21w
innovation_station
i have decided to make the single unit first ..  useing the last coil i just wound ..
this will be called the !PAC RING OF POWER ...
THE SECOND UNIT WILL BE CALLED THE !PAC RING STACK ..
IST!
innovation_station
HERE IS THE !PAC SINGLE BASE CHARGER CONSTRUCTION VIDEO
stars on 54
W
http://www.youtube.com/watch?v=TZ6Z8aYDhWo
innovation_station
THE SIMPLE just went crazy ... : )
i added a few more things to the base charger ...
added
8 aa enegizer rechargeables 2500 mah  they get recharged from the 6 solar cels on the top of the unit ..
they then power 4 jt's 2 pnp and 2 npn .. : ) :p   4 feeds at 3vdc ..  maybe 75 ohm ...
i will recharge the entire bank of aa's at 3vdc ..   and discharge them in pairs of aa's ; )
the 4 unit pnp npn unit then charges 6 caps ..  npn go to 1 cap system pnp to the other ..
cap system is  1 5.5vdc 1f supercap and a 5.5vdc .47 f super cap hooked up for 11vdc ..  both sides get those ...  then to a CRYSTAL DIODE .   then to the 2 large caps 17 000 35vdc   then dioded from caps 2 feeds to the 12vdc battery ..
the 12vdc will have aux solar plug in aswell ..  : )
the only job of the 12vdc is to recharge the BOOST CAP POWER RING ..
the rest of the system keeps the 12vdc gel full and ready to go ...
the ring will have attachements ..  for diffrent jobs ...
W
innovation_station
i have decided to use 8 solars to recharge the batteries 2 per 3vdc pair of batteries ..
i put 4 bridges in there from the solars to the batteries then i tapped off 4 feeds to supply the npn & pnp 4 banger
its a slow process but it sure looks good!
i used all plexi glass so it is all see through ..
i took pictures of the entire thing .. i will make another video soon the entire unit  and all the parts used to build it  start to finish
W
there 5 transistor cans in the base charger 3 npn 3055 and 2 pnp 734 2n5871   all diodes are fr306  3amp 1000v
