IST RING OF POWER
Started by innovation_station, March 05, 2010, 03:28:51 PM
innovation_station
Quote from: onthecuttingedge2005 on March 05, 2010, 08:24:15 PM
if you spent as much time in this as solar technology we get some where.
http://www.youtube.com/watch?v=5m8LgiYpfDI
im on the next video already ...
thought to manifastitation  in seconds ...
ist!
innovation_station
innovation_station
how many special people change ? wake up the doll and ask her why!!
wipe that tear away now from your eye.. : )
W
innovation_station
here is the wired cradle charger unit for the ring stack ..
http://www.youtube.com/watch?v=9jNWEwVZTiE
ist!
innovation_station
was thinking i better throw 2 of thease in there  ....
http://www.youtube.com/watch?v=-TLskSe5DUs
1 in the ring with a push button switch to check the charge ..  and a inferred sencer on the on the first led..
to sence when cap voltage is too low for usefull  cap charge ...   meaning when the voltage drops to a certain point ...  the unit pops out of the sweet spot ..  so it is best to keep it with in working range ..  wich is set by voltage of supply ...  btw .....
;0
i use a 270 ohm 5w in my gator coil charger  it operates 12vdc i have other coils that use 5k 8w   but this coil seams to work much better ....  it is low mass copper pulse and trigger coil same wire length diffrent gages ...  : )
i use a 1n4001 diode for FEED BACK ..  on the ALI COIL it works quite well .....
the other unit is to be mounted in the base charger  to monitor the charge of the BOOST CAP  when the blue led lites ...  i should be able to use a blue led the same to trigger the charger to shut down ..  with a little effort i should be able to figure it out on my own ...  but someone else with experience in the feild feel free to jump in .. on that deal ... : )
W
