Fibonacci, platonic solids and Vortex coils
Started by Mk1, March 09, 2010, 10:39:44 PM
jeanna
Wow Mark,
This is a nice job and very promising.
I need a drill press to make one of those as well.
Did you try that in cardboard?
I am assuming you have and the pressures got too big for the cardboard.
My other question is about how many layers you will be making.
You only need 2 on the cardboard design. Or, really only one layer but with 2 wires.
Is that single layer  part of the design the same for now?
thank you,
jeanna
Mk1
Quote from: jeanna on April 05, 2010, 02:19:24 PM
Wow Mark,
thank you,
jeanna
First the picture , the big one is the one i used , its 47 pegs 15 layers 3 turns , i needed it to be at least 3 cm tall .
What i plan on doing to make one then take the nails off turn the coil a bit put the nails back and put the second layer , then the secondary then 2 more layers winding the 2 new coil in the hole left by the nails .
I could also go one layer/pickup coil/second layer/pickup coil/first layer/ pickup coil /second layer , nicely wound together .
God knows i will see.
Also i new thing came to my mind the layer can go in the same direction the coil dose or not (smaller drawings)
