Fibonacci, platonic solids and Vortex coils
Started by Mk1, March 09, 2010, 10:39:44 PM
Mk1
Quote from: stprue on March 27, 2010, 06:19:36 PM
Beautiful coil design but way to complicated for hehe..... ;D
Maybe , but i got tired of playing with leds an cfl , we need real power .
I takes the same juice the Slayer coil takes , don't get confused by the cell phone charger .
You see they cross at 90 degrees , tilting the wire at 45 , make the work the way we always seen it work .
I need grunt , to power household appliances .
The nature is the same on many levels , the truth is about double helix .
That is why my coil works so well , it has direct magnetic coupling , but no direct on so you cant load the source , this is why it works so great.
Mark
Edit . now why do like the double helix so much ?
Because it make a perfect coil .
ElectricGoose
Quote from: Mk1 on March 27, 2010, 06:26:15 PM
I takes the same juice the Slayer A takes , don't get confused by the cell phone charger .
You see they cross at 90 degrees , tilting the wire at 45 , make the work the way we always we think it dose .
Mark
Mark
Yah, I have seen those honeycomb coils before and the chopstick jigs you use to wind them.  I'm just wondering if all that crossing over at right angles will have the same 'cancelling' effect as your first coil though before you began winding parallel?
E-Goose
Mk1
@egoose
We don't see it because the core is in the way but the coil cross in both of my types of coil.
I will make a drawing of what i mean for perfect coil.
Also i made some test with pvc , besides to fact that it works really badly
when comes time to wind it , because the cardboard hold the wire better.
But i am not sure this is why you had issue with yours , but i can say that if i use only 18 turns primaries , the output light leds only at 36 the bulb start working.
ElectricGoose
Quote from: Mk1 on March 27, 2010, 06:49:20 PM
@egoose
We don't see it because the core is in the way but the A cross in both of my types of coil.
Champion!  Looks like some rewinding is in order then *sigh.  I still havent found some big tube dang it.
E-Goose
Mk1
Quote from: ElectricGoose on March 27, 2010, 07:02:04 PM
E-Goose
Don't you have comet cleaner ,or duck tape .
