Self running coil?
Started by gotoluc, March 13, 2010, 12:40:57 AM
HarryV
Quote from: gotoluc on March 17, 2010, 07:56:42 PM
Thanks Harry
Luc
Here it is as a jpg and pdf
Let me know if it is ok.
Harry
gotoluc
Quote from: wattsup on March 17, 2010, 09:46:14 PM
@gotoluc
It is very simple. Your bucking mode wound but reverse connected coil is doing a double wammy.
When the first wound coil starts getting energized, it is already starting to impart to the core that already imparts to the the 2nd coil, and when the same discharge that hit the first coil now reaches the second coil that was actual precharged via the core, this then imparts to the core that imparts back to the 1st coil just before it gets hit again. 1st coil gets hit, imparts to second, then on top of that the 2nd gets hit then imparts to the first. So instead of doing the standard pulse one coil and draw off the other, when the charge finally leaves the coil, it had underwent a double hit on the core which forcibly translated to an added exchange to the output.
The best part of that is when you will one day wind a bucking primary over your existing very very nice thin 30 awg actual secondary. You then replace all the connections that went to your secondary to the new primary then feed off the secondary to send it also back to source. This should charge your battery. lol
Also, imagine instead of putting the five layers per coil then out of each, you make first layer first coil, then go to first layer second coil, then 2nd layer of first coil, then directly to second layer of second coil, all the way through the five layers. What would be the result? Why do I say that. Because of your loose winds, I don't think all five layers are required for that size toroid core but all five would be more useful as described successive mutual layers. That would be like a 10 wammy. I wonder if the result would be additive or compounded. Let's ask a banker. lol
I really like what you do @gotoluc , very inspiring, so please keep on digging it up.
So much fun.
Hi wattsup,
yes!!! so much fun and so much left to test.
Thanks for your input. I like the flip flop layers. That is on the list to test. Believe it or not I also had the same idea. We can go out to town on this one ;D
See my next post.
Luc
Magluvin
Harryv
You will have to recheck the way the coil is wound. It wasnt a typo on the drawing. =]
Where the coil ends meet, both will be coming out of the core from the inside of the core.
Mags
SkyWatcher123
Hi folks, sorry for having same name almost skywatcher, but i have it in the other forum.
hi luc, this reminds me of an invention in an older pdf i think from panacea, heres the pics.
peace love light
Tyson :)
gotoluc
Hi Everyone,
as you may of noticed in my test 5 video I do have a second toroid. It also has 2 separate half windings but both windings continue the same way. I wound that one in purpose to compare it the the fist one (windings opposed)
I wound it with the same wire and also wound 6 layers per side to get a higher Inductance. I was very surprised when I connected my Inductance meter and found each coil to be only 220mH compared to the first one at 260mH. I was even more surprised when I combined the coils and it is only 890mH :-\... compared to 1,043mH from the first one.
I don't understand that one ???... more wire, same core but less inductance!
VERY IMPORTANT NEWS
I just finished testing that second coil (both wires going the same direction) and I can't get it to do what the first coil does (send back energy)
The best I got was at 15vdc at 28ma. I tried everything I know to date and this one does not do it.
I think this would be important for replicator to know.
Luc
