IST'S CAM CAP CONVERSION DEVICE !
Started by innovation_station, March 19, 2010, 12:33:11 PM
innovation_station
well
i have decided to build a power box ..  that is solar pannel driven  uses 2 rechargeable batteries .. and powers  ??
well  i will say at this point ... the limits are UNKNOWEN..
WILLIAM A. FILSINGER
DESIGNER , INVENTOR..
ONT. CANADA!
as per time and date ..
got to get chuch back here .......
as this is a power device for the young ring ..
innovation_station
i have an old plastic dremmel box i will mount  the cams in and the solar pannel and the aa's
i have a small plastic box for the caps the relay and the pwm ..
i have room to add a wall outlet ...  to plug in light bulbs and lamps ...
FOR NOW!
W
i have enough room for 3 cam boards .. if i require more output at 1 time or if i choose to run the pwm faster ...
i will INSTALL A TURBO BUTTON !!
LMFAO!
innovation_station
the device as explained is still only a single stage device ...
and im simply draining the first stage  the ideal design it a 3 tear cascade device ..
however ..
i want safe stable clean renewable power SECOND TO NONE !
and i can achieve more than most require from a single stage ..
innovation_station
innovation_station
this is going to be the
!CUBE !CON
IT IS A CONVERSION DEVICE IT OPERATES ON A SINGLE AA BATTERY TO 4 AA ..
depends upon required operation of the device
i am adding a outlet for lights .. loa's many it will drive UN MODDED ...  tested and released public!
aswell it will burn filiment bulbs of higher wattage!
it will power heaters .. of small scale
i will also add the young ring recessed plug .. it is also a stage 2 power supply  system
this output can be used for MANY THINGS. I will further explain ..
ist
