Duplicating the Moray Device
Started by HUMPHREY, March 19, 2010, 10:00:43 PM
Pephyon
Someone help me translate this guy ???
cletushowell
Ill try again sorry
1 realize the capacitor/battery is the
   Granite
2 your filling the granit with uv radiation
   Frequency from antenna
3 the frequency is held in by the box
4 the trapped frequency is spiraled through
   Series
5 the end of the spiral goes to water
6 the water keeps the energy flowing
  One way through the granite to the
  Earth so your water has to have either
  Another antenna from it or to earth
7 Getting the circuit started requires getting
  The energy to start going through
the granit watch my you tube earth
battery i hit unlimited volts and amps ac and dc
and wireless
8 understand unless your moray valve
   Is converted to the exact frequency
   Of the coil filament its not going to
   Light a bulb or turn a motor
9 so you need a jouel theif circuit of some type
10 so tesla stuck gaps between the motor
    Points in the car and spirals in the bulbs
    So jp morgan can sell it to us
11 understand this principle square wave
    Spiral the spiral coil reveres thru the middle
    Of the wave magnifying the power
    Of trapped and released radiation
    So im thinking a sheet metal bent
    In square wave with reversing spirals through
    it above the granit moray built cells i think
    Theres a way easier way to just set the
    Metal above the granite trap the frequency
   In shape
12 with photon you can get lost by thinking
    The longer the wire the more power on the probe
decibel but its not its the longer the wire the less energy
the more gaps or lost frequency
The higher the metter reads but thats the wrong
way with the right help we can cut his 50 foot
wire to none good luch
cletushowell
Yes the bent metal or box is the
key the granite was in the box truck
before i spun the grinder and then under a
patio so the patio must been corigated
metal the square wave ill go back by and double check
the patio construction
cletushowell
Ok i built the square sheetmetal
wire spiral
Im not a very good engineer
of this but it parralel the spiral
by opposite spirals through the waves
then its serries metal in series
so the end result is now my
ac and dc current matches
so this proves ac an dc are the same
both photon some one said that all overunity
combines ac and dc at least the best do
this is the design at least i beleive it is
that matches them equaly
Pephyon
Thank you for the better version. Do you have a photo or sketch available? It would be good visualize/figure the whole thing. I appreciate your good will. Thanks.
