Duplicating the Moray Device
Started by HUMPHREY, March 19, 2010, 10:00:43 PM
cletushowell
Oddly enough my spirals equal my mv
so if the spirals were increased mv
should increase and
also with a sliding trigger type circuit
the voltage can be interrupted at
any wind of the coil to match any power
source so my gas peddal would be on the side
of the tesla coil like those electric cars
from toysrus as my motor speeds up i can increse
the power frequency like adding
coils to a ac motor for variable speed but my coils are all in line
maybee someone understands
cletushowell
Well im not going say it works till i do
it but i was wrong its only 7x3
21 mv because were not following the magnificance
of 3 6 9
so follow the math if the first coil is 3 loops
and all coils after a 3 the voltage stays
21 mv but if the voltage is squared
by doubling the loops in each square
3 6 9
then our power should magnify by the square
not the loops so we should go
21 mv
4.41 v
194.481
and then the wopper
37,822,859,361 enough power to
generate earthquake 333
shatter the glascier so if you get a earth
quake youll know it works although i think the kicker
is changing the super conductor at once
so how do you step the voltage of 37 billion
down if your still only at square 4 and
only 18 winds oh 18 is revelations
the 666 so im almost there rest the seven
should be the whole 144,000 then by manipulating the coils to
the math to double the speed of light
should be fun ill keep you updated hope im right
does anyone know if square wave squares energy
I dont know anything about these waves
but sounds right to me
cletushowell
Ok the first 3. 6 9
increased 1000 times not squared
so some how it has to circle that back
thru again so i went .230mv  to 230.00mv now
im in mv but the coils should step up
volts the same but im going from frequency
so the abilty to tune the frequency up and down
the tesla coil into the battery should parralel
the frequency of anything into the battery
and thus contiual to circle the  energy
proble like this two tesla coils between square spirals
steps the receiving voltage thru magnificication
coil then to the sending coil where it enters again at higher
power level to be magnified again so probly not perfect but
close i dont beleive tesla used crystals
not shure but i think by intercepting the
spiral in the middle you can tune the frequency
of the tesla coil to the frequency of anything
changing specific gravity by unlimited circling
of power then match the frequency
between antennas to wireless device
thats my theory from where im at in testing
hope this helps
stprue
Do you have any pictures or videos of your tests?
cletushowell
I guess in a short sentence it works like this
everything operates at 144,000
so im taking that in at 144,000 the middle but if I magnify
it then send it out at say 100,000 frequenct then receive that
100,000 back in the receiving coil
to continue to be magnified the voltage /amps the whole time feeding
144,000 in the center then its continualy
building energy at 100,000 frequency
with then gives you two constant
very powerfull frequencies and should continue to build
i dont see how it could stop unless you do like tesla did
and smash it with hammer but i dont know you need
the transmiting coil frequency is already changed by going thru
any object but its not controlled so because he was attached to his beam the frequency was his building sorry i know im typing a lot it helps me to think it through
