Bruce's Discovery, Tesla's Missing Link for his Unipolar Generator!
Started by Bruce_TPU, March 21, 2010, 07:22:45 PM
Bruce_TPU
Hi Pese,
Not with one magnet, but MANY magnets, all north facing in one direction and south facing in the other direction.  I know when you slap steel on top of the North Facing Magnets, that the North Field will be through the steel and even strengthened.  (picture is a few posts above)  But...What I don't know and GB will test and let me know, if the Unipolar Faraday's Paradox is applicable, or if I will have to use large magnets that will rotate on their axis.  these are too costly.  In the days of old, they used Electromagnets for this size, but this is a waste, when seeking OU in such a device.
I hope that GB's test shows that it will work.  I want to build a full sized machine.  ;-)
Cheers my friend,
Bruce
pese
Quote from: Bruce_TPU on April 04, 2010, 04:30:48 PM
Hi Pese,
Cheers my friend,
Bruce
I hop, that you find it out.
I know, and i test this out this moment.
wif you take some strong magnets
- al with same polarity , on an disk
(not even on the ouside limits.)
than you will have  on the outsided plat surface no magnetic flux.  Even if you tak an 0m8mm plate ( from pc-case , i tested this als,  only you find an very weak
magnet field, that is not to use in your application
the magent flus om an magnet wil ONLY rum the shortest was from (possibly his own)  moth to South direction.
So the Flux only run, on the magnet-side of the plate
N to S.
If you will run ypur device - as you think to work with this.
you will find another way to bring the flux to transversing the flatcoil.
Take a look to hardisk magnets.  and to horse-shoes-magnets.
that it can work.
this system is als usefully for  wind-wheel-generators.
othewise , to much (un-neded) losts in soft working magnetfields.  Im am wondering since years over this...
Gustav Pese
gravityblock
Preliminary tests appear promising at this moment.  I took the lid off a one gallon paint can to use as my steel plate, around 6" in diameter, and attached many 0.5 inch diameter neo magnets to one side of the lid (My neo magnets are very thin and not very strong, they're like button magnets).  Then I took a can opener and cut the bottom of a vegetable can (3.75 inches in diameter), and attached it to the other side of the magnets.  The magnets are sandwiched between the lid of the paint can and the face of the vegetable lid.
I then took another magnet in repulsive mode and moved it over the face of the lid, and the field appears to be uniform like a single magnet around the entire diameter and area of the lid ( I didn't feel any spots on the lid where the magnet was attracted to it, except around the outer edges of the paint can lid.  Moving the magnet over the lid was nice and smooth with no jerky motions).  The field from the lid, both attracts and repels the other magnet.  The other magnet starts to respond to the face of the lid when it is 4 inches away, and will try to turn when in repulsive mode, in order to align with the field from the lid.
The next test is to rotate the lids, and take measurements. I can't use the lid from the paint can as my conductive disc, because it isn't conductive.  Maybe if I sanded the lid it would be conductive.  The bottom of the vegetable can is conductive and I will use this as my conductive disc for this test.  If I get a relatively good voltage (it will be low in this case, but should be much higher than a small diameter magnet), then the steel plates can be used as one large diameter magnet.
I really like this concept.  If it works, then I can further my research into this area.  I have been limited to small diameter magnets, which doesn't work very well in these experiments.
[Edit:]  I will take a video and post it on youtube if the experiment is successful or not.
GB
dutchy1966
Hi Bruce and GB,
You might want to have a look here. It's about a homopolar generator that uses multiple magnets arranged in a disc structure like the two of you are testing. It seems this should work flawlessly.
There might be some more to learn there as well.
http://www.stardrivedevice.com/over-unity.html#intro
Hope it is of some use.
Good luck!
regards,
Dutchy
gravityblock
Quote from: dutchy1966 on April 05, 2010, 07:03:26 AM
Hi Bruce and GB,
Good luck!
regards,
Dutchy
I'm familiar with the StarDrive HPG concept.  Thanks for posting this, for I had forgotten about it and lost the link to the page.  I have it bookmarked now.
Here's a short video of my setup right now, http://www.youtube.com/watch?v=NRhy4Zy70FY
I'm unable to take any measurements at this time due to poor conductivity on the metal plates.  Some places are conductive, and other places are not (probably due to a thin coating of non-conductive material on the metal discs).  When it's rotating, my voltmeter shows no continuity between the axis and outer edge.
In the video, you will notice when it first starts to run, it has a slight wobble up and down.  If I gradually pulse it until the rotor reaches it's maximum RPM, then it doesn't wobble during the spin-up.  If I don't pulse it, then it will fly off (the metal discs are only attached to the rotor via magnets, with no glue so I can get it balanced).  When the blue light is on, then it is being powered.  The black tape is around the smaller disc to keep the magnets from flying off due to the centrifugal force.  I will be taking measurements between the axis and to the edge of the black tape, which would be equivalent to around a 3.5 inch diameter magnet.
I'll work on a good conductive disc so I can take measurements.  Hopefully I can finish this test today.  I do have some errands to run, so it may be later in the evening before I can make the necessary changes.
GB
