Bruce's Discovery, Tesla's Missing Link for his Unipolar Generator!
Started by Bruce_TPU, March 21, 2010, 07:22:45 PM
gravityblock
Quote from: Bruce_TPU on March 28, 2010, 01:33:06 PM
Hi GB,
You know, it had me thinking... If simply the disc is cutting a the field lines one time, and this is generating the voltage on the disc, could not a series of discs (ie..my tesla pancake coils) be stacked, electrically seperated by perhaps paper?  This could drasticly increase power out, if very thin discs were used (ie..the disc method)??  Your thoughts on this?  Of course as long as the magnetic field strength was strong enough to produce a voltage at the far end, or one could sandwich it between the two magnets in attraction.
I also learned something, for I was under the impression that the disc(coil) had to be sandwiched between a north facing and south facing magnet to produce any power.  This is not the case.  As long as simply one end or the other of the magnet is facing a disc...this means that there should/can be many more spots added to my BRUNG device in which I can take off power, for future experiments.  I LIKE that!
Cheers,
Bruce
I agree, a series of discs/coils should increase the power output, and you are correct about the discs/coils not needing to be sandwiched between opposite poles.  Just take note of the direction the field is pointing in, relative to the disc, and the direction of rotation.
You should take measurements of the disc facing opposite poles, and changing the rotation direction.  I think you will be surprised that both discs will have the same polarity in a, "disc/N/S/disc" setup (you probably won't agree with this until you take measurements).  Also, both discs will have the same polarity in this setup, disc/S/N/disc, but will be opposite in polarity to the discs in the previous configuration.  The polarity of the disc will be opposite in a N/S/disc/N/S configuration, than a S/N/disc/S/N setup.  Changing the direction the field is pointing in relative to the disc, will reverse the polarity, and changing the direction of rotation will also change the polarity.
GB
Bruce_TPU
Quote from: gravityblock on March 29, 2010, 10:12:10 AM
GB
Got it!  Good stuff, GB, thanks!
Cheers,
Bruce
Bruce_TPU
Hello Everyone,
My magnets arrived today in the mail.  I went to put my BRUNG together, but ran into an interesting conundrum...
It seems, that glueing washers to my plastic pieces, in the thinking of just, "sticking them" to the magnet was not as simple as one would think...LOL  It would seem, that it does not, will not stay on the magnet straight.  I find this interesting, and of course the answer must be the air gap in the center.  Hmm...Butch is certainly using an air gap in his magnetic switch.  I just find it interesting, that I never noticed this before or heard mention of it.
So, I will be out looking for "solid" pieces of round steel to epoxy.  I will not glue my magnets to anything, so the round metal will be found...LOL
Cheers,
Bruce  (Dar'ned if I don't learn somethin' new everyday!   ::)  )
Makes me wonder if an airgap couldn't be used on both sides of a "V gate" at the so called "sticky spot"...hmm...that should get some of you magnetphobiacs thinking...
Bruce_TPU
Hi GB,
I am quickly deciding not to go this "super mini route".  I want to do some real testing and really focus my energy on this project, when I conclude my SSG3 experiments.  Trying to wind 20 mini pancake coils is ridiculous and I'd rather just build a large one, and really wind some nice pancake coils, as well as bifilar, to test.  I am going to stack them, one on top of the other.
My question for you, is the following:  If I wanted to use 8" magnets, could I not use an 8" piece of thin steel for the front, place several strong N52 Magnets, all north facing to the steel plate, epoxy them in place and add a thin steel backing.  Or... must it be a true 8" magnet that is rotating on it's axis?  (ridiculously priced, as you can imagine).
If you think my first way will work, please let me know why, and if you have any knowlege of anyone trying this?  Thanks!
Cheers,
Bruce
gravityblock
Quote from: Bruce_TPU on April 03, 2010, 09:59:39 PM
Hi GB,
Cheers,
Bruce
I have done some measurements on this, or at least similar to what you're referring to.  I will draw up a few illustrations to make sure we are talking about the same thing.  You are correct about the larger magnets being ridiculously priced.  My measurements suggests there is a workaround to this problem.
GB
