Bruce's Discovery, Tesla's Missing Link for his Unipolar Generator!
Started by Bruce_TPU, March 21, 2010, 07:22:45 PM
Bruce_TPU
Hello ALL,
Shaft is now installed on first rotor, and the set screw has been tightened with an Allen wrench.  It is looking good, if I humbly say so myself!  LOL
My son asked why I was building it to look so good and I responded that I had "high hopes" that this would be an OU device when completed and did not want to ship something ugly off to Stefan...Hehehe
Next is to make a template for my BRUNG motor's stand. I am thinking on this... It needs to be made out of plastic or wood.... I think wood will work fine.  I also hope to order my ceramic bearings this week.
Cheers,
Bruce
Bruce_TPU
Pleasant Sunday to ALL,
The second shaft is installed securely.  I am now winding my first Tesla Pancake Coil, but ran out of wire.  The roll was 20' stranded 12 awg... so on my way for some connectors.
I love this wire... Winds nicely for pancake coils and has about 42 strands!   ;)  It should do nicely.
P.S.  Thinking about Tesla's disc with spirals, I think of a video I saw today... I have seen many varieties...  A magnet is dropped down an aluminum tube and Eddy currents of course slow it's descent.  I think if that tube were grooved with rifling, like a rifle, (unsure of depth) it would speed the descent of the magnet (thus lessening the effect of Lenz, and using Lenz rather than trying to defeat it)  Just a "half baked" thought for my "half baked" thread!  LOL
Cheers,
Bruce
sparks
Say you drop the magnet down a spiral wound solenoid coil. Store the eddy currents in an indutively coupled secondary that charges a capacitor.  When the magnet exits the tube discharge the capacitor through an accelerating coil that shoots the magnet through a plastic tube back to the top of the column.  Repeat as necessary.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Bruce_TPU
Quote from: sparks on April 18, 2010, 02:37:26 PM
Hi Sparks,
You should try your suggestion Sparks, and let us know how it goes!  Use Alum wire...
Hi GB and Gyula, and all,
I think I have had stumbled onto a great improvement this afternoon, as I wound my first Tesla pancake coil....
What if, between each of the six or eight or however many pancake coils I sandwich between my large magnets, I were to place thin discs of black iron oxide??    ???  Because these are not "typical coils", would that work?  or would it actually hurt the flux field strength reaching the coils??  Any ideas or thoughts?  Of course I have also thought of placing a small thin one between the cores of my many stacked Tesla pancake coils, would that be a better route to go?
@ ALL
I am coating first coil with laquer and have a picture below.  It took every bit of 40 feet for a 10" pancake coil.  So... 40' x 42 strands gives me...1680 feet worth of wire, for magnetic flux field to produce power~!   ;)  With 6 coils, without thin iron powder disc would be about 1.25" seperation between huge magnets (I may be able to throw in a few more, need to see where the strength of the N52's diminish... If any one has some, and a way to test flux field strength vs. distance, please post for me here, inquiring minds want to know.
Anywho, say six coils x 1680 = 10,080 feet of wire subject to a super strength flux field being rotated at high speed... I see a great power potential here...
Cheers,
Bruce
gyulasun
Hi Bruce,
Unfortunately I have had no hands on tests with pancake coils so I refer to this link and the one following it: http://www.overunity.com/index.php?topic=7679.msg237834#msg237834
I think you are going in the right direction with testing flat coils.
rgd,  Gyula
