Bruce's Discovery, Tesla's Missing Link for his Unipolar Generator!
Started by Bruce_TPU, March 21, 2010, 07:22:45 PM
Bruce_TPU
Quote from: Airstriker on April 06, 2010, 05:12:29 AM
Hi Bruce,
Do they sell it to everyone? Or just SKDB related guys ? If you can get them from Steorn, what is the price ? Thanks in advance for that info.
Hi Airstriker,
I have heard back from Steorn and am saddened... How can a company be advertising something they are not yet selling?  Anywho, below was their reply...
Dear Bruce,
Many thanks for your interest in Steorn and ZeroF.
ZeroF is presently at a development stage and will be intergrated into commercial applications at a later stage this year. Hence I cannot provide you with the specifics you need at present, however I will keep your details on file and will contact you in due course - alternatively please visit the Steorn website for future updates.
Airstriker
Yes, that's sad. I've been searching for passive magnetic bearings for a while - the result is also sad. Every single one, I've found, is at a development stage, or nothing physical exists other than a patent. Actually, there are quite a lot of patents. Maybe anybody here was more successful ?
Anyway, what magnetic bearings is CLaNZeR using in his ORBO replications ?
gravityblock
Quote from: Airstriker on April 09, 2010, 02:10:17 AM
I think ClanZer's magnetic bearings are home-made.  Home made magnetic bearings made while in the Steorn Private developers group by Eltimple (check out Eltimple's youtube channel also), http://www.youtube.com/watch?v=__KxFo9ATD4
Halbach Arrays can be used for passive magnetic bearings.  One pole is external and is strengthened, while the other pole is internal and is nearly canceled.
This video demonstrates a simple Halbach Array, http://www.youtube.com/watch?v=Iq72vb6o3Tg
Here's a circular Halbach Array with a simple configuration, http://www.youtube.com/watch?v=qv-9IAj_YnI
Wiki has a good article of the different types of configurations for a Halbach Array, http://en.wikipedia.org/wiki/Halbach_Array#Halbach_cylinder
Passive Magnetic Bearing Development by NASA, http://www.grc.nasa.gov/WWW/spacemech/workshop02/mag-brg.html
ClanZer demonstrating a Halbach Array, http://www.youtube.com/watch?v=zzV6vMG31Mc
This looks promising also, http://www.youtube.com/watch?v=utrHUq4WRsY
GB
gravityblock
Welcome back Bruce.
Short video of my HPG Test Rig, http://www.youtube.com/watch?v=f2WC6Mmk2pc
It's not finished yet.  I need one bearing to hold the end of the axle, and I need to find a good axle that will attach to my Dremel Drill (the axle in the video is for demonstration purposes only).  I have plans to add a center piece that is adjustable in order to shorten or extend the axle according to the different configurations I will be testing, such as multiple magnets/discs, etc.  I still need to work on making my large diameter magnets/Discs.  I could always make it a HPG/mini-lathe (I always wanted a lathe).
I will be testing the Pancake Coil configuration also.
GB
Bruce_TPU
Hi GB,
Nice start you have there, with your build!  I look forward to your progress...
Thanks for the links on the magnetic bearing info.  I will probably just start off with ceramic bearings for my initial testing.  I need 1/2".
I have purchased a 1/2" hollow steel rod for my shaft.  I also now have 2 pulley's with 1/2" bore holes, that will be welded to my new plates.  These will hold the shaft.  I found some lovely 10" tin circles that I will be using.  Not the 12" I wanted, but it is what was readily available.
I will now start to order a few magnets at a time.  This is where it get's expensive... I am going to go for broke and go with N52's, 1".  This should give me excellent penetration by the flux field of my bifilar pancake coils I will be building and stacking.
I have purchased 2 rolls of 20' of 12awg stranded. Low resistance, and is stranded...should give me the high amps I am wanting.
My initial thought is to go with 4 sandwiched between NORTH and SOUTH plates, but we will see.  If field is strong enough to penetrate, I may throw a couple of more in the mix.
Not sure how to drive it...will probably use a dremel or drill for testing...
Designing a motor (or way) to spin the thing is a whole other challange.
Cheers,
Bruce
