IST'S NEOZAP POWER GAP POWER SUPPLY 1 AA BATTERY
Started by innovation_station, March 25, 2010, 12:54:37 PM
innovation_station
this is a unit that uses a cam flash board and an aa battery to charge a 50 vdc 20000 uf cap .. i bleed off the big cap at whatever voltage i desire..  and fill lower uf value caps for dischargeing through the neo zap electrical amp!
a mot primary and a neo zap power gap tap!
ist!
innovation_station
now if i wanted this power unit to run FOR EXTENDED PEROIDS OF TIME
i would use 4 d batteries at 1.5 vdc source voltage and fire a few cam boards ...
then just flick the boards once the big cap is topped up ...
1 2 3 4 1 2 3 4   2 seconds each off for 2 seconds .. switch   i can do it with 3 as i have a simple chaser unit but it runs much faster ..
W
innovation_station
i managed to find 8 fugi cam boards all the exact same all run from aaa
i will use thease to make a power supply
i have 3 big caps 50 volt 20000 uf each they will become voltage translateing batteries
i found about a 10 " pipe to mount it all in ..
i can use the boost cap to supply it or aa's or c or d's ...
undecided yet ..
output goes to the neo banger
