Bedini window motor CEMF switch how to settings?
Started by Arthurs, March 27, 2010, 02:48:14 PM
Arthurs
Hello, everyone:
Been unable to understand how settings the Bedini window motor CEMF switch? In particular mechanical structures? Is best to have the structure to indicate picture
Thank you.
the_big_m_in_ok
Quote from: Arthurs on March 27, 2010, 02:48:14 PM
Hello, everyone:
Been unable to understand how settings the Bedini window A CEMF switch? In particular mechanical structures? Is best to have the structure to indicate picture
A.
@Arthurs
I assume you plan to have the CMEF reed switch(?) near or on the coil?  With something like a magnet-studded bicycle wheel, with North poles outside, attached to a variable speed motor?
--Lee
Arthurs
Quote from: the_big_m_in_ok on March 27, 2010, 04:57:10 PM
@Arthurs
--Lee
Thank you very much the_big_m_in_ok
However: what time this switch should be open, what time should be closed?
Very much like to be able to detail.
Thanks
the_big_m_in_ok
Arthurs said:
... However: what time this switch should be open, what time should be closed?
I was led to understand in my readings of written materials, that the systems should be self regulating in speed by the action of the transistor/magnet interaction.  After you start the wheel with a push, it settles on the right speed by resonance and runs itself indefinitely.
--Lee
