I'd be Making Plans to Leave the US Right About...Now
Started by Cap-Z-ro, April 07, 2010, 12:54:03 AM
Cap-Z-ro
happyfunball
The history of information/disinformation surrounding conspiracies is a very interesting topic. Overall, on a social consciousness level, the push is to categorize conspiracies as 'theories' until somehow proven, which is pretty much a dog chasing it's tail. A conspirator, by nature, most often sets out to make it appear as if there is no conspiracy. It's human nature.
IceStorm
Quote from: allcanadian on April 08, 2010, 01:59:15 AM
@Icestorm
Good you have already figured out what is required but do you do not know it yet. A directional antenna must be required and we can conceive that our device must act in the same manner as radar. Radar sends out a directional signal and listens for the response--it's own echo, but what if our radar was specifically tuned to see only one object?. That is our directional antenna sends out an impulsive directional signal on one frequency and listens for it's echo on another frequency. There is also the issue of power, do you think that in this instance we would need a continuous signal when all the information we need is contained in a single impulse reflected back to it's source?. It would seem far more efficient to maximize the magnitude of the impulse and decrease it's duration as one single impulse has within it any frequency as a function of time. Power is Volt-Amps(watts) but energy is power over time (watt-seconds)thus we can have very high power transmissions of small duration which require little energy. Next, as we have increased magnitude and decreased duration at no expense to power transmitted we can simply construct our receiver so that the 1/4 wavelength of the signal on the incoming antenna produces a voltage peak at the diode junction, this in turn produces a voltage peak on the re-transmission antenna which is encoded as the voltage waveform rises at the expense of transmission power. You see when we solve problems we must be precise in our thoughts, we must view the problem for what it is and solve it systematically, generalizations or assumptions of anything cannot help us in this respect.
AC
I don't think that can work the way you describe it but i can be wrong too. At least you came with rational explanation and a logical description, i have great respect for that.
Best Regards,
IceStorm
the_big_m_in_ok
Quote from: IceStorm on April 07, 2010, 07:53:54 PM
Your not off topic a bit ?? Maybe better to keep your A thing for yourself.
I and others said the same thing.  TS indicated himself, in the past and on another thread, he wasn't capable of that kind if discipline or self-restraint, or whatever you want to call it.  When someone asked him to stop, he said:
"Consider it done."
Logic seldom has any effect of these types of religionists, and I honestly admit myself I'm a regular congregant at a synagogue!  Jews don't publically proselyte.
I don't think TS can change.  I realize this rant is off topic, but I don't know of any way I can select a software switch to ignore him.  The software needs to be rewritten, or an improved version bought by hartiberlin(Stefan), for that.
--Lee
Pirate88179
Quote from: the_big_m_in_ok on April 08, 2010, 01:49:37 PM
"Consider it done."
--Lee
Lee:
Just go to your pm preferences section and anyone that you place in your block section for pms automatically have all of their posts to you blocked as well.
It is easy to do and it works very well.
pm me if you need any help.
