GENERATOR- YOU DO THE IN/OUT POWER MATH
Started by magnetman12003, April 19, 2010, 09:16:15 AM
Rapadura
Quote from: DeepCut on April 23, 2010, 03:59:23 PM
But i'm loving it. I hope we don't discover free energy because then i'd have nothing to do in my spare time ;+}
Gary.
I don't know why, but I feel that you are very close to dicover something very very impressive... And if you do it, please share with us. If you see a selfrunning overunity (or "overdouble")  device spinning right before your eyes without any external energy source, please don't have a heart attack because of the emotion: make a video of it and put on YouTube!
magnetman12003
[A author=Bruce_TPU link=topic=9076.msg238773#msg238773 date=1272065347]
Hi Tom,
You can easily add the second coil to where the coils can be seperated!  Here is an idea... Take and measure the length diameter you need, to "slip" at 90 degrees over your existing pu coil..  Measure out some Card Stock to the width and length you need to make your desired bobbin.  Cut out several, identical, and glue one on top of another, to get the stiffness you desire for coil form.  Next, simply spray with some good spray adhesive, and then wind your magnet wire (or stranded wire as I prefer in this case) around the form.  At the end of the first row, use wax to start next row, spray again an wind second layer.  Continue this for as many layers as you want.  Slip coil on at 90 degrees and you are good to go!  If it only puts out 1/2 as much power as your other coil, that is okay, you are still up in power output by 50% !!!   ;)
Cheers,
Bruce
[/quote]
Thanks Bruce,
I will do that because I already have a extra coil with wire on it and I can use the wire on it to do the wrap around like you stated. Tom
DeepCut
Liking that idea Bruce, i'm sick of hand-winding 800 turns around plastic piping !
OK, test results.
System components :
Drive coil/circuit: a la Bedini, no relay. Drive component unimportant since could be pulse generator.
Induction Coil : 0.25mm @ 61.1 ohms. No second coil at this time.
Magnet : Neo @ 6,100 gauss.
Full wave bridge rectifier, shop-bought, maximum reverse-current is 10A per diode.
Potentiometer : 10k linear, 3 terminal.
Starting condition :
Input : 12.54VDC @ 0.114A = 1.42956W
Output (rectified) : 40.3VDC @ 0.0085A = 0.34255W
Pot resistance : 0 ohms
Peak performance :
Input : 12.54VDC @ 0.144A = 1.80576W
Output (rectified) : 23.0VDC @ 0.020A = 0.46W
Pot resistance : 7.65 ohms
Bear in mind that Tom has much more wire on his induction coil than i do, although i suppose there is a limit to the length of the induction wire before a critical threshold is reached.
So we should expect better results with Tom's setup.
Gary.
Gary.
Bruce_TPU
Quote from: DeepCut on April 23, 2010, 08:31:52 PM
OK, test results.
System components :
Peak performance :
Gary.
Gary.
Good Job Gary,
Don't be discouraged, just keep on adding and refining!  But the main thing is that your measurments are accurate!  You are having fun and learning alot..., try a second coil and figure out ways to lessen your input power.
Cheers,
Bruce
DeepCut
Cheers Bruce mate :)
Ideas for improvement :
Increase magnetic flux.
Ceramic bearings to reduce axle friction.
Pulse generator instead of bedini circuit, would cut input power costs down.
Increase number of windings in induction coil. *EDIT* and add a second coil ! *EDIT*
Change material of induction coil, silver-coated ?
Gary.
