GENERATOR- YOU DO THE IN/OUT POWER MATH
Started by magnetman12003, April 19, 2010, 09:16:15 AM
DeepCut
Thanks Mark.
I think i'll try the transformer route first. May as well do something while i'm waiting for neon-sign transformers and true sine-wave inverters !
Gary.
DeepCut
OK, my first try at transforming the output and i'm having problems.
When Mark says the primary winding is connected to the motor coil output i am assuming this is the non-rectified output, as it's an AC pulse transformer.
But once i connect the primary winding to the motor coil output i am creating a short-circuit so the magnet stops rotating ?
I put a diode between one motor-coil/primary-winding connection but the magnet still won't spin.
How is this short-circuit problem gotten around ?
Thanks,
Gary.
DeepCut
OK it was just bad contacts !
I have 12 turns on primary and 6 on secondary but voltage isn't lowering.
Will play with it some more tonight.
Gary.
mscoffman
Quote from: DeepCut on June 28, 2010, 12:41:28 PM
Gary.
@Gary
You need to load the transformer secondary down. Like it
would be if it was feeding the motor's input...Without a load
the transformer windings look like a capacitor from primary
to secondary and high frequency pulse pass right through this
cap. As you load things the primary and secondary should start
to have different voltages.!?  You can always take winding off the
secondary...but wait till you can load things down some. AC
RMS scale is not the best scale for pulses. A scope or a DC
bridge before a DC DVM is a better choice. As you can see the
transformer windings can be used to adjust around impedance matching
problems - (hopefully) with some degree of energy efficiency.
If you continue to use the series voltage regulator (which I don't
recommend) you need output voltage +3VDC as input or it will begin
to not regulate properly...I'd wait on this till you get some OU.
:S:MarkSCoffman
DeepCut
Thanks Mark.
I ended up watching two brilliant films tonight so didn't continue.
I'll do it with a load tomorrow and no regulator.
Thanks,
Gary.
