GENERATOR- YOU DO THE IN/OUT POWER MATH
Started by magnetman12003, April 19, 2010, 09:16:15 AM
Bruce_TPU
Quote from: FatChance!!! on June 18, 2010, 06:27:04 AM
If it takes no friction when trying to make a device self run, then it's certainly not overunity.
The only real overunity device is one that is able to self run while sustaining an external load, friction included.
FatChance, FatChance.  Your definition does NOT hold water, I am sorry to say.  FRICTION is not a prerequisite to OU.  More Wattage out, than Wattage in.  DC vs. DC, the output smoothed with a cap.  This is the true test.  Tom shows this but is careful not to go proclaiming it.  If a unit is self running, sustaining itself, it is ridiculous to say that it must have friction to prove anything.  Magnetic bearings is what Steorn Used for their E-Orbo.  So I guess no OU there?
Please less typing and more building...  I am waiting to see your replication, pls.  Of anything.
Have a good day!
Bruce
DeepCut
Ye FC !
What on earth were you smoking when you wrote that  ?
Gary.
DeepCut
I'm wondering how this setup would compare to an SSG for battery-charging ?
I learnt a lot about batteries when i was doing my SSG on the monopole3 group but i never really understood how their COP calculations worked i just stuck my figures into their spreadsheet that they make available.
I have a 6V battery which is at 6.19V which means it is at sulphation point, there is a handy chart half way down this page :
http://www.batterystuff.com/tutorial_battery.html
If i charge the battery from this device i know the energy input taken but how do i calculate what's gone into the battery ?
My battery is 6V @ 4.5Ah so can do 27W for an hour (i think this is right).
So, if it gets charged from 6.19V to a fully-charged state of 6.3V does that mean the power that's gone in is 1.1*4.5 = 4.95W ?
Thanks,
Gary.
FatChance!!!
Quote from: Bruce_TPU on June 18, 2010, 07:09:09 AM
Friction itself is proof of nothing. But I told you the obvious. If a device cannot handle any small load, e.g friction,
then it can't possible sustain itself in closed due to all other losses involved in such a scenario.
There's no proof of any overunity from the E-Orbo except the unverified claims of the Steorn crew.
Omnibus own replication does not qualify as proof yet due to the lack of unbiased verification.
Quote from: DeepCut on June 18, 2010, 07:54:51 AM
None, perhaps I'm just a sane guy that can see through all the smoke and confusion when there is
claims of overunity. So far I have never been wrong. But I do hope I'm wrong this time.
DeepCut
FC.
Tom didn't devise a friction-free magnet/shaft assembly because the device couldn't handle the friction.
He devised the assembly to maximise the RPM.
I hope that clarifies things.
Gary.
