GENERATOR- YOU DO THE IN/OUT POWER MATH
Started by magnetman12003, April 19, 2010, 09:16:15 AM
magnetman12003
Hi Guys,
This is my latest and I am still improving it. Decided to wait for a 2 inch diameter 2 inch long diametric spin magnet to arrive before I look at power in and power out figures.
Made some major improvements to the magnet/axle assembly
Will show that later.
Tom
http://www.youtube.com/watch?v=E20BWoeHCIw&feature=channel
Tom
I'll seriousness and curiousity, how much did filling a patent cost in total?
magnetman12003
First you start with a patent pending good for one year. About $80.  If you cant market the device during that time frame then you are faced spending about $10,000 dollars to go for a real patent thats good for 25 years.
Mind you however if someone else tops your idea by a different way and patents it then you have pounded your money down a rathole.  Your device becomes a mute issue.
Also you run the risk of having the military or some government agency step in and tell you that what you are doing is classified and they will take it from you. As the inventor you might also vanish along with your device.  "MIB visits"
I post all information on what I do on the internet and keep no secrets at all. My commercial concern is to direct any  potential profits to a charity. That why I have a patent pending.
Now the cats out of the bag and the whole world knows about your device  by putting all info on the internet. I am not into this for money or fame just for personal satisfaction that  overunity can  be accomplished.
If someone replicating this device can cross the overunity quest finish line ahead of me and post all their info for others to see I will congradulate him or her and consider my mission accomplished.
Tom
magnetman12003
[A author=magnetman12003 link=topic=9076.msg238202#msg238202 date=1271682975]
This You Tube video shows and tells all.
http://www.youtube.com/watch?v=dj388d43Ufo&feature=channel
I have vastly improved this setup since I posted it.
magnetman12003
I found that the Bedini/Davro setup can spin a Diametric ring magnet continuously at hi speeds and uses very little watt power to do so regardless of the size of the magnet.  At least up to 2 inches in diameter so far.
Having said that a certain shaped wave form unique to the Bedini/Davro setup is generated by the circuit that powers the Bedini coil.  I noticed that the SPINNING MAGNET ITSELF DOES ALL THE WORK.  It attracts to and repels from the weaker Bedini coils shaped wave form pulses. The spinning magnet also cuts through its own flux coil producing energy.
If the Bedini coil itself was powering the spinning magnet the input current draw would be out of sight and the input watt power as well.   Thats not the case here.  Build the device and see for yourself.
As a result maybe we can produce a larger output than input using a large Hi N  number spin magnet.
Thats were I am now.
Tom
