Breakthrough with the Anton HHO cell !
Started by hartiberlin, April 25, 2010, 02:33:30 AM
ZathEros
Quote from: sushimoto on May 06, 2010, 01:29:36 PM
..And where are their videos showing a motor running
or at least some brazing torch?
here is a video of their smaller cells producing hho gas and a welding torch burning.  2 small cells running 23 amps producing 3.5 Liters a minute, not bad-
http://www.youtube.com/user/jermy342#p/u/11/VHpEHNtTcyc
There is no video of them running a motor I am just posting the link for an alternative to anton  for the USA folks. Much less expensive.
follow the other youtube links for additional comparisons.
Z
mscoffman
I seem to be doing this a lot.
Reposting something that Paul-R posted in another thread.
This link is on the Bob Boyce Electrolyser;
"I am not sure that I am right here, but it may be that this is what is
meant:"     http://www.free-energy-info.co.uk/D9.pdf
There are quite a few pictures and diagrams that help explain what
goes into making any working electrolyser cell. The different two
electrolytes ect.
It also gives hope for separating drive electronics and using
the power supply with any appropriately sized cell hardware.
I happen to think that there are more then one valid overunity energy
source and some folk want to tie them together to create "secrets".
For example Bedini combines static electricity generation and CF inside
acid/lead storage batteries, the way Boyce combines CF in electrolyser
cells with magnetic overunity in toroidal pulse driver electronics to create
sufficient overunity for his self-running racing boats. So, I assume that
Anton electrolyser hardware could be combined with the appropriate
overunity driver to produce more then overunity energy then is being
shown. I don't like these secrets because they deny others the
understanding about what is going on while they make constructing
these things a high technical chore. I don't mind paying for twenty
of these things to heat my home but if they are not overunity I might
as well be using resistance heating.
By the way I want to say that I appreciate other posters for their
comments and the links provided.
:S:MarkSCoffman
Rapadura
Two weeks later....
When will we see another 40 seconds video?   :-\
markdansie
There are at last count dozens of companies proucing HHO cells. Some have ben pperating for near 2 years producing commecial welders, and stoves. Many smaller backyard enterproses also exist some producing good products other junk.
There are also some large companies proucing HHO cells fro the trucking industry some with reasonable results.
What i have seen here is a reasonably proced cell that is about as efficient as many others.
But to claim it is efficient enought to self run an ICE is both false and misleading and seems to be to promote a few sales. You run and ICE you would at least need 5 times whatthey have now and where is the evidence??????. I amhappy to sen some of my team mebers to report back on any demonstration they care to do as a third party collaberation. I have been testing and building these devices for years along with many thousands of others.
So when I ead they have had it run for hours I see an untruth if it cant be substaniated.
One tell tale sign...in the 40 second run ...where did they get the gas to start it????? Was a bateery involved.
I have seen a 300 HP V* run on HHO but after a few minuts the battery went flat. So if it is truly self running, please have the demonstrate it by disconecting the battery after it has started.
The other problem I have they use a couple of lights and drills and claim look 1000 watts. Rubbish
vrand
Quote from: markdansie on May 08, 2010, 05:56:55 PM
The videos are proof that something very unusual and exciting happening with the Anton Cell.
What we know:
- Not OU gas production at 2.5 Wh/L
- Is OU in HHO Gas energy content.
Theories on Anton HHO Gas OU Energy:
- Orthohydrogen has greater energy than Parahydrogen.
- The Anton gas maybe has higher percentage of Orthohydrogen.
- Dr. Moray King's theory of the third gas he calls "Charged water clusters" taps into ZPE.
- Brown's Gas researcher calls this third gas "Electrified water" and can fuel an engine.
More reproductions is needed to verify the Anton cell's OU HHO gas output can power other engines.
This is the first time, on video, of a selfrunning HHO cell powering an engine with extra power for loads.
We all look forward to seeing more on this exciting OU HHO discovery.  :)
Regards, Mike R.
