Breakthrough with the Anton HHO cell !
Started by hartiberlin, April 25, 2010, 02:33:30 AM
Omnibus
Quote from: Rapadura on April 25, 2010, 03:22:45 PM
Technically, it's not "overunity" or "perpetual motion", it's "using water as a fuel".
Anyway, it's astonishing!
I hope more tests are done to show that it can run for longer time just on water. And I hope it can run on sea water, because potable water is very scarce in our planet, and can't be used as fuel!
Not so. If what they claim is true then this is overunity par excellence. Water cannot be the fuel in this case because they are spending energy (spending fuel) to split water. This has to be understood very well. The only thing is is what they are claiming really true and this can only be understood and confirmed by independent studies.
Here are a few pictures of the Anton cell and the modified cheap
chinese motor-generator.
These 2 plastic gears were used to  make their own
ignition system to control the sparking at an adjusted phase
angle versus rotor position from top dead center.
With it they could varify the degree from TDC to have thee
spark ignite and supress the waste spark as it occurs in normal
ignition systems.
With this they can control the ignition timing of the motor
for optimum mechanical and thus electrical output from the motor-generator.
The injector was modified to have an about 30 cm hose at the intake
to let the HHO gas mix with external air
and the HHO gas is put into it the hose via  a hole as you can see above from
the injection01.jpg picture.
The right length of this hose is very important to have the right air-hho mix,
Oliver said today to me.
Regards, Stefan.
Omnibus
So, this generator used to split the water is powered by what's produced when splitting that very water and some part of that product (of the split water) remains for other purposes (other than feeding it back to run the generator), correct?
billmehess
What is a Anton cell? What does it do and what is its configuration. Stephan you say they power them with the power supply... Wait a minute if the power supply is producing enough energy for the cell to produce 6 liters per min of HHO  this is all meaningless.
What is the voltage and amperage from the power supply. With enough amperage any amount of HHO can be produce to run anything. I am sure I am missing something here
so please all you good people out there please enlighten me.
