SM's TPU SUMMARY. What We Know So Far.
Started by FatBird, May 02, 2010, 08:11:57 PM
otto
Hello all,
@fritz
in the "end" is the heatsink muuuuuch hotter then the MOSFET.
If the MOSFET would have the same temperature as the heatsink, the MOSFET would melt.
Otto
nickc44
Otto
How are you its been a long time hows the progress
I know your having a ball
Drop me a line when you get a chance
Nick
Jack Noskills
I recently watched a video where De Palma was explaining his N-machine, homopolar generator. Magnets attached in copper disk and when disk is rotated you get electricity from the copper. Axle is one terminal and outer rim of disk is the other, this is the basic Faraday thingie. Then he said that it is not necessary to have the copper disk, it is enough to rotate the magnets and you can get electricity straight from the magnets. This implies that field of a magnet does not rotate with the magnet.
Some facts I have learned about SM TPU. It has a rotating magnetic field, so it is taken from Teslas trafo patent. In the video SM says that TPU needs a magnet to operate, does not work otherwise. SM also says that you need primary in different phase, to me this sounds that you need only one frequency to operate.
Now combine what De Palma has said with what SM has said, do you see the picture now ? Instead of rotating the magnet, magnet is stationary and you rotate magnetic field around the magnet instead. Magnet poles become your terminals. In order to get voltage, two magnets are combined together maybe using iron wire that is the core at the same time.
I think this is worthwhile to test. First of all, can you take electricity out from a magnet ? If true, how does this correlate to speed of field rotation ? Does core need to be aircore, iron or would higher permeability core make any difference ? How can you increase voltage if core is for example nanoperm or metglass ?
Tesla used iron, so maybe better to start with that. Also 1/4 L rule could be used, core is of length L and quadrants are of length L/4. Then sweep with signal generator for a sweet spot if any.
I am unable to test this, but I wanted to put the idea here since I haven't seen this approach mentioned anywhere. If someone has tried this then please post some links for results.
e2matrix
Jack Noskills,  I think your points are good and I've also come across info recently that said there was success with just using one frequency rather than 3 frequencies but that one frequency needed to be 3 different phases.
Bruce_TPU
Hey guys, the TPU does not need a magnet to operate.  It was smoke and mirrors for the investors.  Closed a reed switch to start the oscillations.  Also used to protect the controllerfrom the IM products messing the freqs.  It also had a small battery.
Cheers,
Bruce
